Frankentruck issues
Old Jan 4, 2012 | 05:29 PM
campbell87's Avatar
campbell87
Frankentruck issues
I currently spent a year building this truck. I took a 351 windsor motor and drivetrain out of an 85 and put it in a 97 eddiebaur f150. Got everything where it should be and drove it home. Here are my two problems. When i want to start it now for some reason i have to pour gas into the carb, because its not delivering like it should and two i started the truck and for some reason the lights were dim. i shut off the lights and ten minutes later they were bright again, i took the truck down the road and the battery died. My alt is putting out the correct amps but somethings not working right. any help would be greatly aprieciated. anyone who does this sort of thing knows the amount of effort i had to put into this so you can understand how bad i would like this truck to just run correctly
Old Jan 4, 2012 | 08:05 PM
Ole' gray's Avatar
Ole' gray
As for the electrical issue, sounds like a bad battery, or a really bad drain somewhere
Old Jan 4, 2012 | 08:13 PM
Edgethis's Avatar
Edgethis
Make sure the alt is putting out 14.4 volts.
Is the carb adjusted properly? Might be a leak at the bowl.
Old Jan 5, 2012 | 01:11 PM
campbell87's Avatar
campbell87
yeah im gonna replace the carb and see if that makes any difference, now if my voltage regulator wire wasnt hooked up right would those electrical symptoms act like that?
Azazic
83
Apr 23, 2018 08:51 AM
dieseldrew
2009 - 2014 F150
Jul 15, 2017 04:11 PM
MI79250
19
Dec 31, 2011 12:18 PM
Steves55
17
Jan 13, 2011 03:25 PM
SmaulzEB
1978 - 1996 Big Bronco
Oct 5, 2003 10:17 PM
