Gas Tank
Old Feb 17, 2012 | 04:14 PM
  #31
BobbyFord's Avatar
BobbyFord
My theory is if it's your time to go then it wouldn't matter if you are in an M1A1.
I might not be too bad on a harp...
Old Feb 18, 2012 | 02:20 PM
  #32
undertakerman's Avatar
undertakerman
I'm working on a 1968 F100 and I have relocated the gas tank from inside the cab to the rear of the truck behind the rear end inside the frame. The tank is a 21 gallon NoLimits tank that I designed. The filler neck comes up in the bed on the left side of the bed at the tailgate and is painted flat black and undercoated to make it unnoticeable. I also ran new gas lines and added a fuel filter at the tank and a drain plug in the bottom of the tank. The stock pump on my 360 is strong enough to pull the gas.
Old May 24, 2012 | 08:23 AM
  #33
5oh's Avatar
5oh
Originally Posted by f100today
I just finished mine; Jegs 20 gallon fuel cell....
It is nice having room behind the seat!
You wouldn't happen to have the part number for this cell?
Old May 24, 2012 | 04:55 PM
  #34
f100today's Avatar
f100today
JEGS Performance Products 15345 JEGS Aluminum Fuel Cells
Old May 24, 2012 | 05:04 PM
  #35
f100today's Avatar
f100today
Why is everyone talking about getting rear ended? Who gives a sh..? Might want to think about a car running a light and nailing the side of the cab right behind the door. THAT is when I do not want to have a fuel tank 3 inches behind me. Go ahead and rearend me with the tank behind the axle. Thats gonna have be one heck of a hit. And if you get rearended hard enough, it just might make it up to the cab mounted tank anyway. It happened to a guy here in Ft Worth last year. Driving one of these trucks and was plowed by an 18 wheeler so hard the front bumper of the 18 wheeler was in the dudes seat. The truck BURNED and he DIED. I will buy my time with the tank 5 ft further back in a run of the mill rear end accident and don't have to worry about a side impact.
Old May 28, 2012 | 09:14 PM
  #36
Blue Oval Farm Boy's Avatar
Blue Oval Farm Boy
Also, remember, starting in 1973, FORD installed the tanks between the frame behind the rear axle and I have never seen one of these explode or burn. I have seen a couple with the rear bumper pushed just about even with the back of the cab though.
David.
Old Jul 24, 2012 | 11:57 PM
  #37
boo-yaa138's Avatar
boo-yaa138
I just finished mine; Jegs 20 gallon fuel cell. I trimmed the next to last cross member, fabbed a fuel cell mount and cut a hole in the bed. The pics make the tank look like it hangs way below the truck but it really does not. Maybe 2 inches below the bumper line. I could have got it another inch or so higher if I would have taken the time to do some more fabrication; time is a factor though. I still have to put hinges on the door with a latch. I have aftermarket gauges so the 0-90 sending unit worked with them. It is nice having room behind the seat!
do you have any more pics from the back? maybe one that is farther back. i would like to see how much of the cell you can see.
Old Jul 25, 2012 | 07:53 AM
  #38
5oh's Avatar
5oh
Jaz 254-016-01
I used a JAZ 16 gallon tank from Summit (Jaz 254-016-01) in my 67 Ranger. I also could have gotten it in there an inch or 2 higher but time was a factor. The picture is a bit of an illusion though, since it was taken well below the bumper line. I also could have gotten it in a little higher by turning it around., but I wanted the sump aimed to the back of the truck. Some people flip them around and run the lines out the front. Since I plan on popping wheelies, I didn't think that was my best option.
Old Jul 25, 2012 | 11:22 AM
  #39
BlueovalFE's Avatar
BlueovalFE
Wheelies
I saw a bumper sticker the other day that said, "Wheelstands are a sign of poor suspension". No doubt, but they are fun to watch
Old Jul 25, 2012 | 12:21 PM
  #40
smokenchoken's Avatar
smokenchoken
i know its not to much better but a buddy of mine bought a diamond plate aluminum tool box put a couple racing fuel cells in it it works great and its safe plus he installed a fuel switch since he runs race fuel in one side and pump gas in other side i have wanted to do this ever since..... simple, safe, effective, and additional cool factor
Old Jul 25, 2012 | 05:15 PM
  #41
BobbyFord's Avatar
BobbyFord
Yeah. Make sure you post the youtube video link when you get those front wheels off the ground
Idahobob
1947 and Older Ford Trucks
Sep 20, 2014 10:39 PM
suntaster
15
May 6, 2009 07:36 PM
billy12360
Mar 21, 2008 12:08 AM
topmoo
Aug 9, 2004 07:52 PM
Little Bro
Jul 28, 2004 10:38 PM
