I have a 77 with a 400 and a c6 I don't have reverse lights and it starts in any gear I just wanna fix that I was wondering if there was a cheaper way than a new safety switch I'm open to suggestions thanks. The po mangled the wires up pretty good I'm trying to decipher most of it
I have a 77 with a 400 and a c6 I don't have reverse lights and it starts in any gear.
The backup (reverse) lamps work thru the Neutral Safety Switch (NSS), located at the bottom of the steering column thru 1977.
C7TZ-7A247-A .. NSS (Motorcraft SW-600) / Obsolete from Ford / Available from autoparts stores.
Applications: 1967/77 F100/350.
The NSS is operated by a spring steel selector lever. It snaps onto the shift tube thru a hole in the mast jacket (steering column shroud). Its knife blade end fits into the NSS.
What happens to it: The knife blade end is notorious for snapping off, and/or it loses tensile strength and falls off the shift tube. When either occurres, the truck can be started in any gear.
