neutral saftey switch
Old Mar 12, 2010 | 08:27 PM
Voodoo ChildVood's Avatar
Voodoo ChildVood
Smile neutral saftey switch
Hello,
I have a 71 Ford F100 with a C-6 Tranny. Can anyone please tell me if the neutral saftey switch operates the back up lights or is there a seperate switch for that and if so, where is it located. Information is very much appreciated!!!
Old Mar 13, 2010 | 12:24 PM
7283-F250's Avatar
7283-F250
I am not positive but I think it does.
The pin on the neutral safety switch that the colunm is supposed to control is broken off on my '72 w/ C6. I have no reverse lights when colunm is put into "R"
Old Mar 14, 2010 | 05:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C7TZ7A247A .. NSS (Motorcraft SW600) / Fits: 1967/77 F100/350.
The backup lamps are controlled by this switch.
Where is this pin located...on the NSS itself? Or does it snap into the shift tube thru a hole in the mast jacket?
1965/77 F100/350's have a spring steel NSS selector lever (looks like this: )--- ) which attaches to the shift tube.
The tip of this lever fits into the NSS, and is notorious for snapping off.
DOTZ7B097B .. NSS Selector Lever / Obsolete
AUBURN MOTOR CO. in Auburn ME has 1 = 207-784-2321.
NORTZ & VIRKLER FORD in Lowville NY has 1 = 315-376-6594.
MILLER OBSOLETE PARTS in Binghamton NY has 2 = 800-546-7278.
GREEN SALES CO. in Cincinnati OH has 33 = 800-543-4959.
Old Mar 14, 2010 | 08:38 AM
dwildey's Avatar
dwildey
Yes - it does control the reverse lights and also prevents the truck from starting in gear.
It is towards the bottom of the steering column on under the dash. There is a metal tang that snaps down onto the column and the switch is screwed on with two screws. If is broken, get one from a junkyard.
It also may just need adjusting - loosen the screws and it will move to the left and right. You can also manually test with car off and in reverse to see if lights come on.
Old Mar 14, 2010 | 08:59 AM
Voodoo ChildVood
Smile
Thanks for the help, it is much appreciated!!!
Old Mar 14, 2010 | 12:09 PM
NumberDummy
Originally Posted by dwildey
There is a metal tang that snaps down onto the column. If is broken, get one from a junkyard.
Uh huh...that is...if...you're lucky enough to find one that's isn't broken.
As noted in post #3: DOTZ7B097B (replaced: DOTZ7B097A & C5TZ7B097A) .. NSS Selector Lever / Obsolete
Fits: 1965/77 F100/350.
In addition to the sources I listed above > >
GALPIN MOTORS in Van Nuys CA has 1 = 818-778-2005.
JOE HILLER FORD in Escalon CA has 2 = 209-838-3535.
ROBINSON FORD SALES in Calexico CA has 2 = 760-357-3141.
WOLFE FORD in Lidgerwood ND has 7 = 701-538-7337.
PARTS INTERNATIONAL in Farmers Branch TX has 17 = 888-737-0418.
Plus...there are 102 more scattered across the US at FoMoCo dealers, obsolete parts vendors.
Old Mar 16, 2010 | 06:46 AM
dwildey's Avatar
dwildey
I was lucky enough and got mine and the switch at a junkyard for $5.00. - Maybe it's a California thing?
(There is still hope at junkyards finding treasure from another mans "trash!")
Last edited by dwildey; Mar 16, 2010 at 06:47 AM. Reason: missing bracket on quote
Writemcowboy
Apr 14, 2014 09:02 PM
rangergirl94
16
Feb 21, 2012 07:21 AM
stoney720
Apr 19, 2011 11:26 AM
jeffschreck
1978 - 1996 Big Bronco
Mar 12, 2006 08:06 PM
Johnny1369
Electrical Systems/Wiring
Jul 19, 2002 08:08 PM
