Neutral Safety Switch screws
Old Sep 19, 2010 | 12:40 PM
bkaul's Avatar
bkaul
So, the '74 F-100 I bought is missing the NSS entirely. I've ordered a new one, but since the screws are gone too, I'm not sure what size/thread they were. Anyone know what size/thread screws I should use to match the holes in the steering column?
Thanks!
Old Sep 19, 2010 | 12:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bkaul
So, the '74 F-100 I bought is missing the NSS entirely. I've ordered a new one, but since the screws are gone too.
Welcome to FTE
C7TZ7A247A .. NSS (Motorcraft SW600)
2) 20384S .. Bolt-Mounts NSS to steering column ~ 1/4" -20 x 1" hex head.
Fits: 1967/77 F100/350.
Since the NSS and attaching parts are missing, you may need something else. You may need it...even if you have one.
D0TZ7B097B (replaced D0TZ7B097A & C5TZ7B097A) .. NSS Selector Lever / Obsolete
Fits: 1965/77 F100/350.
This spring steel lever [looks sorta like this: )--- ] with its knife blade end snaps onto the shift tube thru a hole in the mast jacket.
The knife blade end fits into the NSS. This lever's knife blade end is notorious for snapping off. And/or the lever loses tensile strength and falls off the shift tube.
Since this part is obsolete, this may be the reason the NSS was missing, for without this lever, the NSS will not work. It's hard to find...if someone doesn't know where to look.
If you need one...
JST AUTOMOTIVE in Lebanon TN has 5 = 615-443-3086.
GREEN SALES CO. in Cincinnati OH has 27 = 800-543-4959.
Old Sep 19, 2010 | 01:13 PM
bkaul's Avatar
bkaul
Hrm ... Thanks ... That looks like the right switch, but the mounting screw holes in the steering column definitely aren't as big as 1/4-20. Looks like maybe a #8 or so ... I can pick up a couple sizes and go by trial/error, but I figured if anyone knows already, it'd be worth asking.
Thanks for the tip on the lever too! That does seem to be missing as well. The P.O. just cut the wiring off the switch and jumpered the electrical connector so it'll start in any gear and the reverse lights are never on.
Old Sep 19, 2010 | 05:08 PM
bigfoot22's Avatar
bigfoot22
Dennis Carpenter has them for around 12 or 13 bucks.Just my 2 cents.
Old Sep 19, 2010 | 08:49 PM
bkaul's Avatar
bkaul
Sweet. Thanks!
1loco
13
Nov 1, 2014 09:58 AM
sammycooks
May 6, 2011 04:46 PM
94 smokin stroker
Apr 20, 2011 07:21 PM
Wayne S
Sep 13, 2010 03:54 PM
PW01
1983 - 2012 Ranger & B-Series
Sep 15, 2006 02:26 PM
