Minnesota Chapter Join Chapter, Leader: fordpower88
It's 2012 already??? BS Thread
Old Jan 5, 2012 | 02:28 PM
  #301
fordpower88's Avatar
fordpower88
Originally Posted by DieselCamper01
I am leaving right now Troy!
We will set an extra spot at the table!
As the car warms up it starts to whine so Dave first thought was power steering, which was low, so I topped that off. Still whining under acceleration. When I drove the car to see first hand what was going on I noticed as soon as the whine starts it starts to shift hard between gears. Bangs in like I just put in a mild shift kit.
Intake is leaking a small amount of antifreeze externally. Not sure about internal. If it is internal it is too small an amount to smell in the exhaust.
That sucks about the tranny Jay! Intake leak is bad enough let alone trans too.
And somehow when I did the seat heaters I caused a ground to short in the air bag system so now that light in the dash is on.
Could have been worse like the airbag going off! Easy to fix light.....remove bulb!
Old Jan 5, 2012 | 02:37 PM
  #302
DieselCamper01's Avatar
DieselCamper01
Even eaasier fix. Black electrical tape. LOL
Old Jan 5, 2012 | 03:08 PM
  #303
Banage's Avatar
Banage
Hi all!! will some one please tell Duluth its JANUARY!! It should be -30 and 6 feet of snow. Not 44 with not a flake to be counted
Old Jan 5, 2012 | 03:17 PM
  #304
DieselCamper01
Haha! Good luck. Maybe the lake is keeping it too warm...
Old Jan 5, 2012 | 03:27 PM
  #305
fordpower88
Yeah this weather is just crazy!
Ok didn't Tom say he would love to have a diesel in his old caddy....... Well if it can fit in this pickup it should fit in a caddy!
453-T Detroit Diesel in 1950 GMC 2 - YouTube
This thing sounds mean as hell going down the road! Gotta love those old screamin Detroits!
twin stick shiftin' - YouTube
Old Jan 5, 2012 | 03:52 PM
  #306
Ford79's Avatar
Ford79
That thing sounds wicked!!
I've always loved the sound of those Detroit's.
Old Jan 5, 2012 | 04:16 PM
  #307
DieselCamper01
That's pretty cool Troy. I don't know much about those kinds of engines and trannies but is that a "normal" shifter setup or does that have an addition like Gear Vendors set up?
Old Jan 5, 2012 | 04:37 PM
  #308
fordpower88
Yeah those are pretty cool!
Yeah a lot of the old trannys in trucks were called twin sticks so basically two trans. They had a five and a four speed. We had one in an old grain truck on the farm and it was a handful shifting that thing!
Here is a better video of a guy shifting one.
Twin Stick Pappy - YouTube
Old Jan 5, 2012 | 05:12 PM
  #309
Ford79's Avatar
Ford79
There's something you want to drive through rush hour with....... or not.
Old Jan 5, 2012 | 05:38 PM
  #310
HP junkie's Avatar
HP junkie
Ok, dumb question. The little yellow dipstick is the oil, right? I was wondering cause it doesn't have any in it.
Also the side pic is for Jay, I shined it up for ya!
Old Jan 5, 2012 | 05:47 PM
  #311
HP junkie's Avatar
HP junkie
Ok, I watched the twin stick video. The respect I have for the old time truckers! I watched him shift that thing like ten times and it sounded like he was going about 35mph. WTF! That had to be a chore, just think if you had to clutch and slow quickly, remembering what gear you are in or downshifting to a gear. DANG!
Old Jan 5, 2012 | 06:02 PM
  #312
DieselCamper01
Haha I agree Cory. Man that looks complicated!
That is the chain case gear oil. Not sure what weight it takes but probably about 85W should work fine. Probably drain out anything that might be left and the refill.
Old Jan 5, 2012 | 06:13 PM
  #313
HP junkie's Avatar
HP junkie
OK, so where is the crank case oil or does it have oil in the block?
Old Jan 5, 2012 | 06:14 PM
  #314
HP junkie's Avatar
HP junkie
BTW there is nothing to drain out, EMPTY.
Old Jan 5, 2012 | 06:52 PM
  #315
DieselCamper01
It's a 2 stroke. No crank case oil. It is oil injection and mixes it with the gas. There is 2 stroke oil in the plastic reservoir right?
You may want to remove the chain case cover and inspect those parts...maybe get a new gasket. Either that or the drive shaft seal must be leaking. Or you could just add oil and keep an eye on the level. Clean everything up and keep an eye out for leaks.
