Minnesota Chapter Join Chapter, Leader: fordpower88
It's 2012 already??? BS Thread
Old Jan 31, 2012 | 11:25 AM
  #2206
fordpower88's Avatar
fordpower88
Well it is real close. I just have a few connections to make and that is it. The engine alignment tool showed up yesterday so I have to check that too and then time to fire it up! Should have it running in the next night or two I hope.
Old Jan 31, 2012 | 11:29 AM
  #2207
HP junkie's Avatar
HP junkie
Ok, I got the Xtra 10 all greased up and my rebuilt shock installed. He wanted $125 with the Fox shock, of course I already had a Fox shock so I talked him down to $75 without the shock. He said it is shorter and I will have to move the mounting holes like Mike said. Otherwise I am good to go for proper fit.
Old Jan 31, 2012 | 11:35 AM
  #2208
HP junkie's Avatar
HP junkie
Des' uncle is coming over to check on the gas pressure and such too. I texted his kids to see if they are available to install the suspension. They are a couple of sledheads, so maybe they can do it this weekend with me. Otherwise might have to come down to the metro after work one day.
Old Jan 31, 2012 | 12:23 PM
  #2209
DieselCamper01's Avatar
DieselCamper01
Sounds like a great deal all the way around Cory. If they cannot help just let us know.
Old Jan 31, 2012 | 12:29 PM
  #2210
fordpower88
Looks good Cory! Good luck getting it all back together.
Old Jan 31, 2012 | 12:54 PM
  #2211
HP junkie's Avatar
HP junkie
Yea, I'll need it. Might be a little tough with all the old parts on the tunnel. I think I have her cousin talked into doing it this weekend. He just needs to check in with the girlyfriend. Haha, he better get used to that.
Old Jan 31, 2012 | 12:55 PM
  #2212
HP junkie's Avatar
HP junkie
I wish I would have taken before and after pics now. It would be cool to see how much it changes.
Old Jan 31, 2012 | 01:21 PM
  #2213
DieselCamper01
You will have to move the support plates for the rear mounts at the very least Cory. About 2" forward. The front one technically 3/8" forward.
Old Jan 31, 2012 | 02:00 PM
  #2214
HP junkie's Avatar
HP junkie
I thought the front ones were good. Do you think I have to move the front? I will see what I can find.
Old Jan 31, 2012 | 02:29 PM
  #2215
wildstang's Avatar
wildstang
VT Chapter Ldr
Snowmobile rear suspensions are very sensitive to mounting locations. If you can find out the mounting hole locations for the sled, or similar, that had that suspension it would be very beneficial.
Old Jan 31, 2012 | 03:09 PM
  #2216
DieselCamper01
Using that template that Mike saved to your laptop you would need to move the front mounting point approximately 3/8" for the best results. Depending on the size of the support plate there you may just need to drill a new hole and not move the plate. I cannot remember how big that one was. Shouldn't be more than a few rivets to drill out if you do need to move it.
Old Jan 31, 2012 | 03:21 PM
  #2217
Ford79's Avatar
Ford79
Good afternoon guys.
Originally Posted by DieselCamper01
Happy Tuesday Mike. What is on the agenda today?
A little sled work and that is all for the day.
Old Jan 31, 2012 | 03:25 PM
  #2218
fordpower88
Hey guys! Looks like you are getting Cory all set up and ready to go.
Old Jan 31, 2012 | 03:27 PM
  #2219
Ford79's Avatar
Ford79
Cory, if you use this diagram here http://www.jbshocks.com/x10mount.jpg
I believe you need to move the front holes ahead about 3/8" like Jay said and the plates should be wide enough to accommodate that. In the rear, you will either have to remove the plates and move them forward or install new ones, approximately 2 1/2" forward of the current holes.
The problem you could run into using the front holes as they are is the whole skid will be placed back 3/8" or so too far, and this could cause issues with track tension and weight transfer to name a couple.
Don't let all this scare you off though, it is still a pretty straight forward swap. And you will enjoy the extra suspension travel too.
Old Jan 31, 2012 | 03:51 PM
  #2220
dlibson's Avatar
dlibson
Originally Posted by wildstang
Good morning Dave. How's the back
It is getting better, thanks for asking!
