Minnesota Chapter Join Chapter, Leader: fordpower88
It's 2012 already??? BS Thread
Old Jan 31, 2012 | 04:01 PM
  #2221
msmenne17's Avatar
msmenne17
Afternoon everyone!!
Is it 5:00 yet? I might just take off early anyway. I'm itching to finish up what I started on the house yesterday. Trying to get enough done so that we're ready to paint the main floor this weekend.
I looked at the paint we bought today. We painted our bedroom and thought the color looked really light compared to what we thought we got. I found the sample sheet from Menards. Turns out it is light and they messed something up. The color on the wall and the color on the sample aren't even close.
Old Jan 31, 2012 | 04:25 PM
  #2222
HP junkie's Avatar
HP junkie
Originally Posted by Ford79
Cory, if you use this diagram here http://www.jbshocks.com/x10mount.jpg
I believe you need to move the front holes ahead about 3/8" like Jay said and the plates should be wide enough to accommodate that. In the rear, you will either have to remove the plates and move them forward or install new ones, approximately 2 1/2" forward of the current holes.
The problem you could run into using the front holes as they are is the whole skid will be placed back 3/8" or so too far, and this could cause issues with track tension and weight transfer to name a couple.
Don't let all this scare you off though, it is still a pretty straight forward swap. And you will enjoy the extra suspension travel too.
I did some reading and it doesn't sound too hard. The front worries me. If I drill 3/8" in front of the old hole, it will be very close. Do you think the bolt could ream the hole and slip into the old one? It seems like leaving the front as is and moving the rear would work, but the site said measurements are the most important thing. It probably will be easier watching her cousins do it.
Old Jan 31, 2012 | 04:27 PM
  #2223
wildstang's Avatar
wildstang
VT Chapter Ldr
Good to hear Dave. So will it eventually get back to the way it was before it happened?
Old Jan 31, 2012 | 04:28 PM
  #2224
HP junkie's Avatar
HP junkie
Well, her uncle stopped by today while he was on his route. We determined that the orifices are too big. He called "his guy" and has a complete lp kit w/ orifices coming. We will get that in and if it acts up, I will use it for target practice. Hey Troy, got an anchor for your boat? LOL
Old Jan 31, 2012 | 04:31 PM
  #2225
wildstang's Avatar
wildstang
VT Chapter Ldr
You could take some gauge sheet metal and plate the outside of the tunnel in the hole area and rivet it on and drill the hole through both. I need to do that to mine in that area because the tunnel is cracking around the bolt holes
Old Jan 31, 2012 | 04:40 PM
  #2226
fordpower88's Avatar
fordpower88
Hey Michael! Nothing like painting a couple times to finally get the color you want. haha
Well that would make sense if it wasn't swapped to LP. The NG orifices are bigger there for letting to much gas out.Hope that solves your trouble and no I don't have an anchor yet! LOL
Old Jan 31, 2012 | 05:15 PM
  #2227
Ford79's Avatar
Ford79
I've read that the front has to be located an inch higher as well, can't find any confirmation on that though. Seems to be a crap shoot on info out there. Just search xtra 10 swap and you will see what I mean.
Damn, I hate when the orifice is too big................
That would work too.
Old Jan 31, 2012 | 06:13 PM
  #2228
HP junkie's Avatar
HP junkie
Sheet metal would be the best answer. I think if I reinforced the area as much as I could I would be golden. Then a little spray paint, some slides, gas and..........DADGUM SNOW!
Old Jan 31, 2012 | 06:15 PM
  #2229
HP junkie's Avatar
HP junkie
Yeah, I kinda looked over that part......................must have been drinking that night too.
Old Jan 31, 2012 | 06:18 PM
  #2230
HP junkie's Avatar
HP junkie
I did read a couple articles on it today. I did see that the measurements are the most crucial part. I will read more tonight. I wish there was a You Tube video on it. I can't find any. Maybe I could do one.....................hmmmmmmmmmm.
Old Jan 31, 2012 | 06:25 PM
  #2231
HP junkie's Avatar
HP junkie
Here is a quote from the "guy" that did it to his sled.
"The measurement discrepancies that are within 1 inch can all be made up with the track tensioning adjustment".
Does that refer to the front 3/8"?
Old Jan 31, 2012 | 07:08 PM
  #2232
MisterCMK's Avatar
MisterCMK
I've got a Derdge V6 Troy can have for a boat anchor.
Old Jan 31, 2012 | 07:10 PM
  #2233
Jbotto's Avatar
Jbotto
Evening guys! Been catching up on posts from this weekend. Fun weekend, didn't do too much, but it was good to catch up with friends! Chris you get your Trijicon sights yet?
Old Jan 31, 2012 | 07:29 PM
  #2234
HP junkie's Avatar
HP junkie
Well Des' cousin can't help this weekend. I am going to see if I can get someone to swap Sat. with me so I can maybe do it next weekend, unless someone plans on having a GTG so I can try to make it.
Old Jan 31, 2012 | 07:30 PM
  #2235
HP junkie's Avatar
HP junkie
Hey Jake, how goes it tonight?
