Pulled my sled in the garage last night to start changing the A arm bushings, rebuild front shocks, change rear springs and idler wheel bearings. But found another repair needed. Got the shocks pulled off and the left side upper attachment point had a piece broke. There is a metal inner hole and aluminum outer and the back hole got egg shaped and flexed the metal portion enough to break it. So I need to weld it back in and make a metal bracket to go on the outside with a bolt hole in it to temporarily fix the egg shape hole. Here is a picture of where the metal piece broke out
