turbo idi?
Old Dec 31, 2011 | 07:04 PM
7.3stroker2215's Avatar
7.3stroker2215
turbo idi?
Thinking about turboing the truck, is it possibleto use a john deere 4430 turbo cause I don't really wanna drop a grand on a banks kit
Old Dec 31, 2011 | 07:14 PM
91dirtydiesel's Avatar
91dirtydiesel
anything is possible, all it takes is time and money. how much $$$ you think it would be to make the exhaust, intake, mount, lines? how good you think it will work with your fuel settings?
Old Dec 31, 2011 | 07:40 PM
kenpobuck's Avatar
kenpobuck
Other things to think of are, what size engine it was designed for, will yours put out enough volume of exhust to spool it or will it over spool it. There is a lot of research to do before jumping and spending your money on a hunch.
Old Dec 31, 2011 | 08:11 PM
7.3stroker2215
I fully understand about the research but I thought maybe someone could point me in the right direction for some info. I know the 4430 turbos are somewhat small so im sure my truck will spool it, I just need more info on how to do it
Old Dec 31, 2011 | 11:08 PM
therifleman556's Avatar
therifleman556
certainly doable if the motors are close to each other in cubic inches. Another thing to keep in mind is most tractor turbos (at least the ones ive seen) are non-wastegated which if the turbo is small to begin with would run the risk of coming apart if you overfueled. When you think of the time and materials to make it work, a grand doesnt seem so pricey for something designed to work on your engine.
bluemtn95ford
43
Jun 1, 2014 12:40 PM
turbill
13
Jul 28, 2011 10:17 PM
frodfreak
Jan 27, 2011 09:01 AM
bcarless
28
Aug 26, 2009 07:31 PM
bassproguy07
Sep 5, 2006 10:36 AM
