Batteries?
Old Jan 1, 2012 | 12:13 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by buttwheat
So your saying group size 27.
I tend to lean towards a Group 24 or 35 battery. A quick search on NAPA and O'reilly shows 24F and 35.
A 27 would still fit no problem though. It's roughly 2 inches longer than the others.
Josh
Old Jan 1, 2012 | 12:17 PM
Bullitt390's Avatar
Bullitt390
Originally Posted by OldStyle
I will get flack for this also.... I run two of the largest deep cycle battery's Costco carry's. Been running deeps in all my trucks for 30 yrs; never a issue.
Go ahead; I know what you'll say.....
It's weird, but whatever works
Heck, I just built an 8 cell Li-Po A123 compact battery for my motorcycle. Weighs 1.5 pounds and has the same cranking power as the old 10 pound 12BS lead-acid battery.
Josh
Old Jan 1, 2012 | 12:40 PM
buttwheat's Avatar
buttwheat
Costco,Walmart,Interstate and diehard(I think) batteries are all made by Johnson controls.
Old Jan 1, 2012 | 12:58 PM
Bullitt390's Avatar
Bullitt390
Exide makes Napa Batteries.
Interstate, I know makes the John Deere brand batteries.
Johnson Controls makes a ton of batteries, like Motorcraft.
There are really only a handfull of "true" large scale battery companies.
Quick Google search netted this Battery Manufacturers and Brand Names List
Don't know the validity of that list, but it is interesting nonetheless. I would tend to think with some re-badged batteries (like Walmart) they get their batches from whoever has the supply and lowest bid. So some are Exide, some are JC and some are Delphi.
Josh
Old Jan 1, 2012 | 01:29 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
From the 1960's into the 1980's, Exide made Auto-Lite/Motorcraft & Diehard (Sears) batteries.
At one time, don't recall the year (I think it was in the early '80's), the Exide battery plant burned to the ground.
No Motorcraft batteries were available for 6 months. FoMoCo Dealers had no other choice, so bought batteries from autoparts stores. Dunno what Sears did.
btw: Thru the 1980's, all Ford service part replacement batteries were dry (unlike today, as AFAIK, all are wet). Dealers had water heater sized cannisters that contained battery acid.
When a battery was sold, the partsguy donned goggles and rubber gloves (if the dealer had any-most did not ), then filled the battery with acid...breathing the fumes in the process.
Old Jan 1, 2012 | 04:48 PM
Bullitt390's Avatar
Bullitt390
It's interesting you still have to do that process with motorcycle batteries.
Josh
Tackelbarry
17
Aug 16, 2016 08:21 PM
Dace
22
Jun 9, 2016 12:50 AM
Miera85
Aug 2, 2012 03:29 AM
dustinova
Electrical Systems/Wiring
Oct 13, 2006 12:22 PM
R Rocks
Sep 22, 2006 09:43 AM
