Banks sidewinder install
Old Jan 3, 2012 | 09:31 AM
  #31
vfelix702's Avatar
vfelix702
Eaton I bet that will sound sweet!!!! Keep us posted when you do... I like following your threads as you get into detail of things and that's excatly the way I do things!!! Keep up the good work!!!
Old Jan 3, 2012 | 09:45 AM
  #32
tjc transport's Avatar
tjc transport
i ain't rite
Originally Posted by eatont9999
I don't plan on doing head studs with my install. I also don't plan on going over 12lbs of boost, so I should be OK. I paid $400 for my 2nd gen Banks kit that is complete, including the sticker, except for the exhaust after the down pipe. I might just go from the DP into a straight 4" exiting after the cab.
use 3 inch instead. the downpipe is 3 inch anyway, and it will fit easier. do not go to 4 inch till you get where you are going with it.
i ran 3 inch to the bed when i had the stacks. i had the 3-4 inch adapters at the stacks.
if you are going to do a bottom dump, put the 3-4 adapter about a foot or so in, it will work and sound just as good, but cost a lot less with the 3 inch pipe.
Old Jan 3, 2012 | 10:08 AM
  #33
eatont9999's Avatar
eatont9999
Yeah, I was thinking about possible problems going to 4" right away so I might have to use 3" until the pipe comes all the way down and parallel with the frame, then go to the larger pipe. I plan on a 90 elbow exiting the side of the truck just like it is now but 4" instead of 2.5". I'm hoping it sounds good with the bigger pipe and gets better flow. I'm not opposed to 3.5" either.
Old Jan 9, 2012 | 02:38 PM
  #34
Country_boy_2007's Avatar
Country_boy_2007
well my gaskets should be here any day now, so ill try this again..lol.
just wondering what are you guys running as far as an intake?
Old Jan 9, 2012 | 02:59 PM
  #35
tjc transport
i ain't rite
i am running a "slightly modified" intake
i took the big old airbox and cut away everything that was not needed.
then piped the cold side to the front of the truck, and made my own cold air intake.
only i never finished it.
it runs fine the way it is, and has been like this for around 250,000 miles
Old Jan 9, 2012 | 03:19 PM
  #36
BullRidnRenegade's Avatar
BullRidnRenegade
Thats the way my intake looks. Homemade pipe to the front of the truck...It was like that when I bought the truck so i dont know how much of a difference it makes, but it runs great with it.
Old Jan 10, 2012 | 09:59 AM
  #37
Country_boy_2007
thats more or less how i was thinking about doing it, how about filters, what are you running
Old Jan 10, 2012 | 11:27 AM
  #38
tjc transport
i ain't rite
i currently have a cone style filter on the intake tube at the radiator support.
since this truck is now only used for snowplowing i don't really need to worry about dusting the engine anymore.
Old Jan 11, 2012 | 12:55 AM
  #39
Country_boy_2007
thats what i was wondereing, i try to stay away from the k&n and those style filters for a farm truck, id rather use a good hd paper filter.
Well its 1:52 am, shes all back together and runnin. took it for a test drive, damn that bade a hellva diffrence. all ive got left is to put the finishing touches on the intake and exhaust, and finish my guages. all in all it went pretty smooth, it is about enough to make you loose your religion getting the oil drain tube bolts in, im suprised i didnt have a heard of nuns show up..lol
Old Jan 11, 2012 | 08:25 AM
  #40
tjc transport
i ain't rite
the vatican has the local convent on speed dial with my GPS coordinates pre-programed.
they always know when i am working on one of those bartstard projects
Old Jan 11, 2012 | 11:50 AM
  #41
Country_boy_2007
lmao, well lets just say i have woven a tapestry of obsenities that is still floating somewhere over lake Erie...
RA31925
New Mexico Chapter
13
Apr 22, 2014 10:40 AM
rcrdps
Jan 20, 2014 07:54 PM
Byron Sanders
22
Sep 4, 2012 05:19 PM
hedhntr
Jun 2, 2010 02:06 PM
bloomy63
Sep 3, 2006 02:45 PM
