Steering Column Removal Help
Old Dec 31, 2011 | 12:25 AM
DeanBob's Avatar
DeanBob
How do you get the automatic steering column out? I've got everything loosened up, but just can't get the shifter linkage, of the column, to fit through the hole in the firewall. Do I have to disassemble the column before I can pull it through the firewall?
Old Dec 31, 2011 | 04:39 PM
RKDxpress's Avatar
RKDxpress
I think I pulled out throgh the cab and out the door. My seats were out at the time.
Old Dec 31, 2011 | 04:57 PM
crewcabfan's Avatar
crewcabfan
have you removed the flange in the engine side of the firewall?
Old Dec 31, 2011 | 10:44 PM
DeanBob's Avatar
DeanBob
Yes, I have everything removed. Just wondering if I have to take the linkage out of the column in order to get the coumn out.
Old Jan 1, 2012 | 05:04 AM
60F100's Avatar
60F100
It will come out. Takes a lot of twisting and turning to get it just right. It will help to have the steering wheel off.
Old Jan 1, 2012 | 05:22 PM
jmf66's Avatar
jmf66
You should not have to remove the linkage from the column... just disconnect the rod from the shift lever. Remove the plate at the fire wall.. it's 4 bolts to the firewall, and a clamp around the column. Oh.. also unscrew the rubber seal from the firewall on the inside.
Darrellt
May 22, 2017 12:57 PM
abriel68
Apr 29, 2013 02:52 PM
My9fam
Dec 16, 2012 10:42 AM
Bigdaddy29384
Feb 11, 2005 05:11 AM
