Identify this on steering column
Old May 19, 2017 | 08:37 PM
Darrellt's Avatar
Darrellt
Hi,
Can anyone tell me what this connection is for on the steering column? The second photo shows the connection coming off the column.
Thanks.
Old May 19, 2017 | 08:52 PM
rusbukt's Avatar
rusbukt
Doesn't look like original steering column. What did steering column come off of?
Old May 19, 2017 | 09:19 PM
Darrellt's Avatar
Darrellt
Ahhh. That makes sense. The front end and maybe the column came off a CV. I assume I can toss then.
Old May 19, 2017 | 09:22 PM
rusbukt's Avatar
rusbukt
Rip-it and chuck-it!
Old May 19, 2017 | 09:24 PM
rusbukt's Avatar
rusbukt
Also check those bolts. They don't look very tight.
Old May 20, 2017 | 05:19 PM
resonateur's Avatar
resonateur
Later column, with neutral switch. Keep it if you ever want to run an auto trans that doesn't have an integral neutral safety switch, or if you ever want to add back up lights.
Old May 22, 2017 | 12:57 PM
Darrellt's Avatar
Darrellt
Steering column
Thank you for your response. I removed the switch. I also make a bracket. Pictured in the inside. Turned out pretty well.
Mr08353
1997 - 2003 F150
Oct 18, 2017 08:26 PM
1976GT
Dec 29, 2015 01:38 PM
Grinchman
Dec 27, 2015 07:38 PM
