Sponsored by: Real Truck
4R100 Case Question
Old Dec 30, 2011 | 12:48 PM
v10kenj's Avatar
v10kenj
4R100 Case Question
I have a 2003 f250 v10 2wd with a 4R100 transmission. After getting an oil change I was wiping down the filter and oil plug and noticed on the back of the transmission on the bottom of the case there is a black circular plastic piece that had a very small amount of seepage. I think it might be just some engine oil on it, but when I went to wipe it down, the black circular piece has a slight amount of movement to it. Is this an overflow seal and should it have a small amount of play?
Old Dec 30, 2011 | 02:08 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Is this on the bottom of the trans, towards the engine end of the trans?
Old Dec 30, 2011 | 02:34 PM
v10kenj's Avatar
v10kenj
Yes. It's on the very bottom of the transmission toward the engine. Right in front of the oil pan.
Old Dec 30, 2011 | 06:41 PM
Mark Kovalsky
That's an access plug. All that rubber plug does is keep dirt and rocks from getting into the bellhousing.
Old Dec 30, 2011 | 09:54 PM
kawkx500's Avatar
kawkx500
Thats your access plug to access the torque converter drain plug if it is equipped with one. If you are getting oil seepage from there, that COULD indicate that the rear main seal in the motor is starting to go bad. Now that is just a POSSIBLE cause of oil leaking from there .. im not saying thats whats wrong with it .. lol. Are you sure that it was oil and not tranny fluid. If its tranny fluid then the front input shaft on the tranny could be leaking. Again just a possibility.
Old Dec 31, 2011 | 08:42 AM
Boris2000's Avatar
Boris2000
Also is it dark oil or light oil? could be the front trans seal.
Old Jan 2, 2012 | 04:43 PM
v10kenj's Avatar
v10kenj
It was just some residue oil from the oil change I think. Pretty dry now. It was just the plug that through me a bit. Thanks for the help.
cmh15
Nov 13, 2015 10:15 PM
Jayybird
6.7L Power Stroke Diesel
30
May 24, 2012 08:38 AM
GANNET2
1997 - 2003 F150
Apr 19, 2011 06:40 PM
Dialtone
General Automotive Discussion
28
Mar 29, 2008 09:19 PM
stutterstan
Nov 22, 2004 10:00 AM
