Bilsteins for Plow Prep Package
Old Dec 30, 2011 | 10:19 AM
slipry14's Avatar
slipry14
Has anyone put Bilsteins on an F350 with the snow plow prep package. Just wondering if I would use the same part #'s. My F350 does not sit level with the SPPP. The front is about 1 1/2" lower in the front. Thanks.
Old Dec 30, 2011 | 12:39 PM
11350KINGRANCH's Avatar
11350KINGRANCH
I have the snow plow prep package and a 2" leveling kit on mine. My 5160's fit fine.
Old Dec 31, 2011 | 10:32 AM
slipry14's Avatar
slipry14
I guess my question is......would I order the stock height bilsteins for an F350 or size for a leveled truck because of the plow package?
Old Dec 31, 2011 | 11:08 AM
Fontana's Avatar
Fontana
I have the F-250 with the snow plow prep package. I installed Bilstein 5100 based on a 350 example in a previous thread. I did not consider the larger springs and my truck rides a lot better! I don't think you will have an issue. Search for Bilstein shock installation with video. You will see the part# shown on the first posting. I have no regrets. Be advised that you may experience a delay in the delivery of the front shocks as they are in very high demand.
Old Dec 31, 2011 | 01:13 PM
GCLL's Avatar
GCLL
Trucksprings.com should have them in stock and they ship fast.
Old Dec 31, 2011 | 03:05 PM
Sportscraft's Avatar
Sportscraft
I have the snow plow prep package and ordered the stock height 5100's, which actually will work from 0 to 2" lift. Depending on the set up the sppp really doesn't add height. In many cases the max front spring is already selected based on other options so the package doesn't actually change much on the front end.
Old Jan 1, 2012 | 12:30 AM
Fontana's Avatar
Fontana
I'm a bit skeptical about the height comment. The sppp springs definitely add some additional height as it levels the truck perfectly. As mentioned the stock height 5100's are listed 0-2" so they are appropriate for standard springs and sppp.
Old Jan 1, 2012 | 02:20 PM
slipry14's Avatar
slipry14
Thanks guys. Ordered the stock size Bilsteins for my F350. The Sppp definitely adds some height to the front, but I would say it is 2" or less.
tom18287
2009 - 2014 F150
Sep 2, 2009 08:03 PM
snapshot
Aug 16, 2009 07:32 AM
cykoticford
Mar 7, 2008 08:31 PM
JeffreyK
Jan 21, 2005 09:53 AM
fordowner4life
Dec 10, 2003 01:05 PM
