snow plow package question
Old Sep 1, 2009 | 08:06 PM
tom18287's Avatar
tom18287
first of all, how do f150s plow?
they offer the package, and with it, you have to get the heavy payload package as well.
does this make the right rougher or does it not change it much?
Old Sep 1, 2009 | 08:14 PM
johnwill's Avatar
johnwill
All I can say is that I pay someone to plow my driveway, which is where I park my 09 F-150..
Old Sep 1, 2009 | 08:19 PM
big_ole_truck's Avatar
big_ole_truck
Snow? What's that?
Old Sep 1, 2009 | 08:58 PM
fordtruckman's Avatar
fordtruckman
Oh the HD springs will make the ride rougher for sure. I have had good luck plowing. I plow mine and 2-3 others, haven't had any problems. I imagine the 09' would perform about the same if not better.
If its just your driveway, and you don't live in North Dakota then I would say you would probably be better off just paying to have someone do it.
Old Sep 2, 2009 | 08:21 AM
george6488's Avatar
george6488
Snow..........in the last 10 years have only seen that stuff on TV. It doesn't snow in Houston, TX.
Old Sep 2, 2009 | 09:33 AM
mstang66guy's Avatar
mstang66guy
I don't think you could get a plow package from the factory on a 150. Only the SD has a plow prep package that I know of.
Old Sep 2, 2009 | 04:45 PM
johnwill's Avatar
johnwill
There is a Snow Plow Prep Package available on the XL and the XLT regular cab or supercabs. Includes "upgraded springs."
It does require the Heavy-Duty Payload Package, as one would imagine.
Old Sep 2, 2009 | 04:48 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
That's why i didn't see it. I tried to build an XLT Scab and I couldn't find the package listed.
Tim
Old Sep 2, 2009 | 05:00 PM
johnwill's Avatar
johnwill
Tim
You mean Super Crew mainiac?
Old Sep 2, 2009 | 05:19 PM
Deluxe05's Avatar
Deluxe05
Per the 2010 F-150 Order Guide (07/01/09):
SNOW PLOW PREP PACKAGE (62S)
Usage:
Increases GVWR
Availability:
  • Requires Heavy Duty Payload Package (627)
  • 4x4 only
  • Maximum snow plow weight, including permanent attachments: See Bodybuilders Layout Book for more details)
  • Regular Cab 750lbs. (700lbs. plow + 50lbs for permanent attachment)
  • Super Cab 610lbs. (560lbs. plow + 50lbs for permanent attachment)
Includes:
  • Spring upgrades
NOTE: Restrictions apply; see your dealer for more information.
If you look up the Heavy Duty Payload Package, it is limited to XL & XLT trim levels....among other limitations.
Judging by the weights listed on the 4th & 5th bullet points, I am assuming that those are the plow weights referenced on the 3rd bullet point. However, I am not sure what the "Restrictions apply" note indicates.
As others have stated, 4x4 + heavy duty payload package = will definitely put you into ride quality belonging to a truck.
Old Sep 2, 2009 | 07:17 PM
tseekins's Avatar
tseekins
Usage: Increases GVWR
Availability:
  • 4x4 only
Includes:
  • Spring upgrades
Outstanding points all around. These days they make fiberglass and or carbon fiber plow blades with minute mount hardware which eliminates most if not all of the hydraulics. They had to do something to reduce the weight when the truck makers took the 1/2 ton solid front axles away and at the same time made them ride as nice as a car.
Tim
Old Sep 2, 2009 | 07:24 PM
Bsimmer3000's Avatar
Bsimmer3000
Ok guys i have a question. What happens when you plow a road and there's an exposed drain cover sticking out the road by a few inches? I seen so many like that around this area and we get some good snow here at times. Wouldn't it mess up the plow blade? or worse damage the truck?
Old Sep 2, 2009 | 07:34 PM
BIGKEN's Avatar
BIGKEN
Bsimmer...most modern plows are either trip edge or trip blade design...so...unless you're a mainiac...you shouldn't cause any damage to your plow or truck.
To the original poster...an F-150 with plow package upgrade not only rides very similar to an F-250...it costs nearly the same also.
Old Sep 2, 2009 | 07:36 PM
Bsimmer3000
Thanks bigken. Wondered how they work.
Old Sep 2, 2009 | 08:03 PM
tseekins's Avatar
tseekins
Not only would I not mount a plow to a 1/2 of today, I'd get a 4x4 ATV and a blade or blower attachment, more fun.
Tim
mattymax
Dec 7, 2015 12:41 PM
Shernius
Aug 6, 2015 04:42 PM
hoss66
Apr 7, 2015 10:28 AM
JoeP53521
Apr 9, 2014 07:46 PM
03SUPERDUTY250
Oct 4, 2010 08:39 PM
