Shock Install, Steering Stabilizer - VIDEO
Old Apr 16, 2012 | 03:19 PM
  #106
SavageNFS's Avatar
SavageNFS
Bilstein 7100 steering stabilizer arrived from the UPS man (I call him Santa...he laughs every time). I don't have time to install it today, but I will tomorrow. I'm excited...my air bags should be here as well.
Old Apr 16, 2012 | 09:57 PM
  #107
treasman's Avatar
treasman
treasman
My 2011 F250 SD, with 15000+ miles on it, doesn't have the death wobble, but if on a little washboard road the whole body shakes severely. Will the Rancho 9000XL shocks take of that problem?
Old Apr 16, 2012 | 10:03 PM
  #108
SavageNFS's Avatar
SavageNFS
I'm sure they will...
Old Apr 17, 2012 | 09:16 AM
  #109
SavageNFS's Avatar
SavageNFS
Steering stabilizer installed:
Never mind how crazy I got with the penetrating oil...it's getting a bath next...
Old May 11, 2012 | 04:02 PM
  #110
porthole's Avatar
porthole
You guys with the MyRide, any idea how much pressure is being applied?
I have the 9000's in the rear and they are tied into the air bag lines. Don't know what pressure is in the bags though.
Old May 11, 2012 | 05:07 PM
  #111
KC8QVO's Avatar
KC8QVO
I wouldn't do that.
I don't know what air pressure is in the lines, but the air pressure is what affects the ride quality of the shocks. There is a piston inside the shocks that, as it is compressed, stiffens up the ride.
The air pressure takes the place of the **** that comes with the shocks. As you rotate the **** there is a rod that protrudes in to the shock to compress the piston instead. Replacing the **** with the air fitting lets the air pressure push the piston.
All the 9000's do is affect the ride quality (suspension travel response). They do nothing to hold a load like air bags do.
Old May 11, 2012 | 05:15 PM
  #112
WK15's Avatar
WK15
Well, the new toys came in today.
Now, I have to figure out how to install them. I have no tools right now.
These are some long azz shocks.
Old May 11, 2012 | 05:47 PM
  #113
2000silverbullet's Avatar
2000silverbullet
Nice!
Make sure you let out some nitrogen on that 7100 (mine shipped with 200psi in it). Doing so before installing will make it easier to compress.
Old May 11, 2012 | 06:22 PM
  #114
WK15's Avatar
WK15
I did notice this point of 200psi of nitrogen.
Old May 11, 2012 | 08:44 PM
  #115
SavageNFS's Avatar
SavageNFS
I wouldn't let out much. The instructions say to install it. Then drive it. If it pulls to the left, let out a little bit at a time. I installed mine and had to let just a few short (less than a second) bursts and it was perfect. A ratchet strap works perfect to compress it to the exact length needed.
Where are your tools? No man should be without tools.
Old May 11, 2012 | 10:04 PM
  #116
porthole's Avatar
porthole
Originally Posted by KC8QVO
I wouldn't do that.
The 9000's are designed to either use the adjustment ****, the MyRide gizmo or tee into the air bag lines.
I have a firestone Tech R4 air ride in my truck and the bags-shocks are tied in as part of the install. More air in the bags - more air controlling the dampening in the shocks.
Old May 12, 2012 | 01:57 AM
  #117
WK15's Avatar
WK15
Tools are on a Barge from Seattle, Washington to Eagle RIver. I hate not having any tools
Old May 12, 2012 | 05:06 AM
  #118
2000silverbullet
See if you can rent some from a local auto parts store (checker, autozone, etc).
A set of sockets and a BFH (to get the old stabilizer out) should be enough.
Old May 12, 2012 | 12:39 PM
  #119
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
BFH doesnt work so good on the stabilizer removal. aside from beating on things (never first choice) there isnt enough room to get a good swing to hit the the square. so you end up boogering the thing without even a guaranteed removal. pitman arm puller pops it off with only about 2 turns of the nut. no penetrating oil, no mess, right tool for the job. 15 bucks at any autopart store.
Old May 12, 2012 | 03:40 PM
  #120
2000silverbullet
Worked fine for me....and it was free..
