Oil Change?
Old Dec 29, 2011 | 01:32 AM
bebeard's Avatar
bebeard
Oil Change?
Hi all,
I am wanting to save a little money and do my own oil change on my 2004 F250. I have the tools, but wanted to know if anyone has put it on video for reference?
thanks,
BRook
Old Dec 29, 2011 | 04:37 AM
npccpartsman's Avatar
npccpartsman
It's very simple to do and I'd urge you to purchase a fumoto valve (replaces the oil pan drain plug) to simplify it even more. You'll need a 36mm socket to loosen the oil cap and something that will contain 4 gallons of oil.
Run the engine to warm the oil and suspend any particulates that may have settled to the bottom of the oil pan. After shutting off the motor, loosen, but do not completely remove, the oil cap so it pops up but still sits loosely on the filter and filter housing. This allows the oil filter and housing to drain to the oil pan and aids in a cleaner job. At this point you can start draining the pan, which will require a 15+ quart container. If you choose to install a fumoto valve at this point you'll be able to use smaller containers later on to catch your oil and make disposal easier since you can turn the valve on and off. Now go back to the filter, remove the cap and the filter will come out with it. The filter snaps into the cap for reinstallation after you change the o-ring on the cap. Lube the NEW o-ring and reinstall the filter/cap assembly. Refill with oil. The whole process takes about 30 minutes (or less).
Old Dec 29, 2011 | 07:44 AM
bebeard's Avatar
bebeard
Great thank you very much!! Gonna give it a shot...
have done it on my gas auto's before... just wanted to see what others opinions are on the Diesel.
Thanks,
Brook
Old Dec 29, 2011 | 08:11 AM
bismic's Avatar
bismic
Our FTE Tech Folder has quite a bit of info in it .............
https://www.ford-trucks.com/forums/8...-6-0l-oil.html
Old Dec 29, 2011 | 09:07 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Hey npccpartsman, where is the best place to pick up fumoto valve for the oil pan?
Thanks,
Old Dec 29, 2011 | 09:20 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Disregard parts man, they are very easy to come by on the internet. I was concerned at first about the valve coming open on its own, but it has a built in locking feature!
I will be getting one soon!
Subzero68
Jan 8, 2014 09:28 PM
Stinkweed14
6.4L Power Stroke Diesel
18
Sep 15, 2011 07:33 AM
Reave1
Sep 4, 2007 09:08 PM
mjlevi
Oct 26, 2006 07:09 PM
Reglob5
Mar 12, 2006 11:35 AM
