I have a question?!
Old Oct 26, 2006 | 06:38 PM
mjlevi's Avatar
mjlevi
I have a question?!
suppose...just suppose, I wanted to change my oil filter without doing a full blown oil change...ok...how much oil would I have to drain out of the pan before I can safely remove the oil filter cap and filter without getting oil all over the place?
Old Oct 26, 2006 | 06:43 PM
mike6.0's Avatar
mike6.0
you shouldt have to drain any oil at all. when the oil filter cap is unscrewd it allows the oil to drain out of the oil filter housing. i would just hold the filter over the housing and let it drip for a second or two and put it in the new one.
CanadaGuy's Avatar
CanadaGuy
You would not have to drain any oil out of the pan. When you loosen the filter cap, all the oil in the resevoir will drain into the pan. Just check the level after to make sure it's right.
Old Oct 26, 2006 | 07:09 PM
mjlevi's Avatar
mjlevi
thanks for the replies!! you guys are the best !!
