np 208 transfer case question
Old Dec 27, 2011 | 06:03 PM
76250_4x4's Avatar
76250_4x4
today i pulled my t case and split the case just enough to clean and reseal the halves ( they were leaking bad) anyways its back together and i noticed that when it is in 2 hi the front shaft yoke spins if i spin the rear yoke. i can grab it with my hand and stop it because it isnt actually engaged, however there is some friction there. did i do something when i split the case? could it just be because there is just no fluid in it yet? i dont wanna put it back in and have to pull it again! thanks
Old Dec 28, 2011 | 02:25 PM
76250_4x4's Avatar
76250_4x4
i pulled the case apart again this morning all the way this time and i couldnt find anything wrong with the shift forks or anything so i put it back together. with the back of the case off i could spin the main shaft and it wouldnt turn the chain. when i set the cover on the chain spins? anyways now that i think of it its done that since ive got it. what could be wrong with it? i would like to get rid of the extra drag im sure its causing. thanks!
powerstroker100
28
Jul 17, 2010 05:23 AM
mrhooie
Nov 9, 2009 05:19 PM
$Simpleman76
Apr 14, 2007 11:50 PM
gearhead351
Mar 15, 2006 01:04 PM
dgeesaman
Feb 26, 2006 10:31 PM
