Transfer case
Old Mar 9, 2006 | 04:14 PM
gearhead351's Avatar
gearhead351
Red face Transfer case
I have a 1984 Ford F250 4x4. I think the transfer case chain needs to be changed because there is a lot of free play in the drive shaft almost a good 1 1/2 inches turning side to side when parked. How do you change the chain? Is this normal? Thanks!@
Old Mar 9, 2006 | 07:55 PM
NavyMIDN08's Avatar
NavyMIDN08
i know my truck always had a lot play in the transfer case, i consider it normal, it helps give you some play if for some reason the tires jump extra, it doesn't snap the case. of course, i could be wrong, but when all play is removed i've found things tend to break a little quicker...
Old Mar 10, 2006 | 06:09 PM
kermmydog's Avatar
kermmydog
You Mean The Yoke Moves 1.5" That Seems Like Alittle Much, I'd Have Someone In A Shop Check It.
Old Mar 12, 2006 | 02:49 PM
NavyMIDN08's Avatar
NavyMIDN08
i guess i must have read that differently, do you mean the yoke moves side to side, or like a 1.5" change around the circumfrence?
Old Mar 15, 2006 | 01:04 PM
millertime300's Avatar
millertime300
Is it the transfercaes/engine tranny that stop the driveline from moving, or the rear end? Either way it sound excessive.
