2nd row door panel drivers side?
Old Dec 25, 2011 | 12:58 AM
Pitcrw6's Avatar
Pitcrw6
My wife put 3 fist size dents in the 2nd row door right above the molding but it didnt crease the metal so I should be able to push them right out. My question is how does the interior door pnl come off so I can access the dents with the window up? Are there clips and it just pulls straight off? Any help would be appreciated.
Old Dec 25, 2011 | 01:16 AM
archtaan's Avatar
archtaan
I believe there is a screw in the rear door. The front has 2 one beneath the reflecor and one around the window/door lock control. It then just lifts up and out. No tight clips.
Old Dec 25, 2011 | 02:22 AM
robert_l_ross's Avatar
robert_l_ross
Per the drawing on www.ford-parts.comm looks like 2 screws...one behind the red reflector, one by the interior door release handle. Like the other poster said, pull UP, then out.
Old Dec 25, 2011 | 06:30 PM
Pitcrw6's Avatar
Pitcrw6
Cool, thanks guys.
Old Dec 26, 2011 | 10:19 PM
Skinsfan6's Avatar
Skinsfan6
The door panels are easy on these trucks. First, stick a flathead screwdriver/knife under the front of the window control board and pry up. It will snap loose, then you have to work it out. Pull the plug from underneath the window switch. There will be a small 7mm bolt that looks like it only holds the front of the armrest to the door, but it also holds on the door panel. The other bolt is also 7mm and is underneath the reflector down low.I use a knife to pop this off too. Then lift up and off. When putting the door panel back on, lock the door, it is easier with the lock down.
Old Dec 26, 2011 | 10:51 PM
robert_l_ross
Is there a light behind that reflector like in the front doors?
DirtyLarry
Jan 18, 2015 08:33 PM
Comanche1Star
Mar 29, 2009 05:47 AM
Powerstroke-7.3
16
Feb 27, 2009 05:27 PM
GeneralC.
Nov 23, 2007 12:54 AM
ExcursionUSA
Aug 9, 2007 05:33 PM
