Do you know if this can be repaired?
Old Dec 24, 2011 | 02:18 AM
76F100SB's Avatar
76F100SB
460 with a long story. tore it down to see what was in it seen this after removing the distributor.
pic problems so far hopefully it works this time.
Old Dec 24, 2011 | 02:19 AM
76F100SB's Avatar
76F100SB
do you think that can be repaired? what do you think caused it to crack?
Old Dec 24, 2011 | 05:44 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
That is a little hard to tell in the pic, but I personally wouldn't worry too much about it. It looks ugly and it would always be in the back of your mind, but I don't see why it wouldn't be serviceable. I am at a loss why it cracked, but I would guess maybe a previous oil pump seizure in the past or maybe the engine was ran without the distributor hold down tight and it bound up, anythng is possible in a 40 year old truck.
Old Dec 24, 2011 | 05:50 PM
montana_highboy's Avatar
montana_highboy
One would think the dizzys shear pin would snap before causing carnage like that, it looks to me like a PO was whacking on a frozen dizzy to free it up and caused that damage in the process.
Old Dec 24, 2011 | 06:02 PM
76F100SB's Avatar
76F100SB
This engine is actually in my 71 cougar. D0VE-A block D0VE-.C heads. Was my step grandfathers he pasted from cancer about 2 years ago engine was balanced blueprinted, forged pistons, scj intake and carb. Had less that 1000 mi on it my grandma figures. It sat for about 4 yrs so when I got it I soaked cylinders, turned it over by hand rebuilt carb and it ran good pulled engine to cleanup and paint underhood and engine. Found roller tip rockers were pretty rust pitted and surface rusted I desided to disassmble alittle further and saw this I don't know if this has been seen before or no. This this was dynoed after built at 550 hp according to the family. Don't want to trash the hole thing.
Old Dec 24, 2011 | 07:01 PM
76F100SB's Avatar
76F100SB
It is actually cracked threw completely in the top of pick deformed area and 3/4 of the way threw near the bottom. Looks like the piece is about ready to fall out.
Old Dec 24, 2011 | 08:42 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
460ford.com
Some good engine builders on there will help out or buy it if you don't want it.
Old Dec 24, 2011 | 09:31 PM
59 shorty's Avatar
59 shorty
ouch!
Looks like someone got a little crazy with a big drill trying to prime the oil system when it was rebuilt. just my 2c. Mark
Old Dec 26, 2011 | 03:31 PM
wdfp's Avatar
wdfp
A good machinist could probably bore it and put a sleeve in it, or you could get another block. Myself I wouldn't leave it that way because Murphy's law seems to run everything I do..
Old Dec 26, 2011 | 03:44 PM
ford390gashog's Avatar
ford390gashog
UMMM? The last time I saw that happen was to a 390 because some untrained person used a slide hammer to free a "stuck" cam. The cam was being held in by the dizzy of course it was not going to move!
gottagojoe
Apr 28, 2011 08:04 PM
jgan
May 5, 2009 11:05 AM
darrin1999
Mar 1, 2008 10:59 PM
Sniffels323
Aug 29, 2005 05:39 PM
jheroux
Apr 8, 2005 10:25 PM
