Inspection pointers
Old Dec 22, 2011 | 10:55 PM
Rick92's Avatar
Rick92
Inspection pointers
I am going to look at a 1992 Ford F250 4x4 Auto tomorrow any tips or pointers I need to know when looking and inspecting this truck?
Old Dec 23, 2011 | 06:16 AM
tjc transport's Avatar
tjc transport
i ain't rite
you want to start it ice cold. if it don't start rite up, it will need glow plug and return line work.
and if the owner uses ether to start it, walk away.
Old Dec 23, 2011 | 08:37 AM
Rick92's Avatar
Rick92
Thanks for that info does anyone have anything else they want to add?
Old Dec 23, 2011 | 08:57 AM
farmert's Avatar
farmert
These old girls need a good electrical system in the starting circut. Batteries should be a matched set of a minimum of 850 CCA. Check the cables for swollen, discolored spots near the terminals. If you find swollen spots, or splits new cables might be called for, not a deal breaker, but the cable is kind of spendy to replace.
Check the fluids, The oil will probably be blacker than the ace of spades, which is normal. You don't want it to be milky colored. The anti freeze should be bright. No rust or oil residue in it. Ask the seller if he used any additives in the coolant. The 7.3 is prone to cavitation. Just a couple of more things to check.
Old Dec 23, 2011 | 09:52 AM
Rick92's Avatar
Rick92
Thank you Sir, are the batteries located under the hood?
Old Dec 23, 2011 | 10:20 AM
tjc transport
i ain't rite
yup, one on each side of the radiator.
check for the overdrive light flashing, that is signs of a possible trans problem.
also check the angle of the front wheels, see if they are straight up and down or look like this/ \ or \ / this. that is a sign of serious alignment problems.
if you can get into sand or something soft, lock it in 4X4 and see if you can spin the front tires when you stomp on the throttle. if they spin, the 4 wheel drive works. if only the back wheels spin with 4X4 locked in, there is a problem there. .
Old Dec 23, 2011 | 10:22 AM
Rick92's Avatar
Rick92
Thanks use to working on class 8 trucks
Old Dec 23, 2011 | 11:08 AM
Ford4Life7.3's Avatar
Ford4Life7.3
This info is for powerstroke diesels but nearly all of it applies to IDI's as well.
Buying Used Power Stroke Diesels
Things To Look For When Buying A Used Power Stroke Diesel
Turbo:
You might take the air tube off the back of the air filter and look inside of it. If there is dirt build up, that is a very bad sign, so are the turbo fins looking sand blasted or bent. A little oily film is normal since the valve cover breather exits inside the tube.
Airbox:
Check the two bolts holding down the airbox lid. If they are plastic with a square recess, it is a recalled part. The recall is expired, but without the updated lid the risk of dirt infiltration is greater, the lid was updated with more supports and the updated bolts are metal with a straight slot. If it is the old style, you spend around $80 to update it.
Tranny:
If you buy a truck with an auto tranny, finding out if it's been maintained is essential, as the E4OD is an expensive transmission. Also, (if auto) seeing if the truck has an auxiliary transmission cooler would be worthwhile. For sticks, listen for clunking when shutting off or small vibration while operating. It could be an indication of a dual mass flywheel going out. Many have replaced them with single mass units.
Rear Gear Ratio:
4:10 will pull better, get slightly lower mpg’s and run a higher RPM compared to 3:55.
Coolant:
Ask the previous owner about the coolant - have they been adding FW16 or DCA4 to keep a proper SCA level? It is very important for stopping cavitation. You can get test strips to check the SCA level from NAPA, International, or Ford. I would test the current condition while looking over the truck, the SCA level should be between 1.5 and 3.0. Also, see if it has a block heater (it was an option on 97's).
Front end:
Check the front end for wear, or have an alignment shop check out the ball joints and steering linkage (tie rod ends). If they are shot, it is spendy (all four tie rods are around $400 just for parts, ball joint labor is also very spendy)
Oil:
The questions to ask are how often the oil was changed (at least every 5,000) and what kind of oil they used (diesel rated)? An oil analysis could tell you if there might be an engine problem or not.
Aftermarket stuff:
Seeing if the truck has got an aftermarket downpipe would be nice, a chip, or gauges (pyrometer, trans temp, etc.). Ask about any added items and who installed them.
Glow Plugs/Relay:
Find out if the glow plugs are in good working condition as well as the relay. Ask if either has been changed and when. You can check the glow plug resistance through the valve cover connector if needed (http://forums.ford-diesel.com/cgi-bi...&f=21&t=005210), and the relay should have power to both large terminals on top when the key is turned on, and one of the terminals should go out before ~2 minutes.
Injector o-rings:
The injector O-rings have been known to be a problem. The new o-ring sets have a pink middle seal. If the truck has an o-ring problem, one of the signs can be a discoloration of the fuel in the filter bowl. There is a drain on the passenger side front of the filter bowl for draining water (the filter is also the water separator) and you can catch some of the drained fuel in a jar – it should be dingy yellow and not blue or dark.
Leaks and Drips:
You can check the valley between the heads of the V8 for moisture and/or fluid. It should be dry not wet. Most leaks will run through this valley and down the back of the motor dripping off by the tranny/engine coupling.
VIN number:
If you take the VIN to any dealer, they can tell you when it was built, when it went into service, and some of the work that might have been done on it. You can also run prospective VIN's through Carfax.com to see the title history.
Wish i could say these were all my ideas, but theyre not haha. oughta get ya started!
Old Dec 23, 2011 | 12:00 PM
Rick92's Avatar
Rick92
Thanks very much that helps out alot for when I go look at this truck.
yz450guy
Mar 30, 2017 08:55 AM
pinehillian
Apr 2, 2013 09:30 AM
lght1
16
Dec 9, 2012 12:45 PM
Phantez
17
Dec 20, 2011 03:29 PM
firefighter15
Oct 23, 2010 10:40 AM
