Won't switch tanks...
Old Dec 27, 2011 | 08:11 AM
strokin'_tatsch's Avatar
strokin'_tatsch
Thanks Jim and Phil. I didn't know the selector valve did the electrical switching also. LOL
The selector valve shouldn't be a dealer only part.. The part stores have them for around $80, but IIRC they are universal. Not sure if they'll bolt right in with no modifications or not.
Old Dec 27, 2011 | 08:49 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Originally Posted by cowmilker08
Have you ever tore apart a selector valve? There is a little electric motor in there that turns a screw. The screw causes a unit to move laterally inside the housing that has two functions. First, the unit's motion operates a plunger that slides past the fittings that go to each tank, blocking off one tank at a time. Secondly, the unit has electrical connections on it that move with the unit. In one position it is connected to the wire the goes to the fuel level sensor for that tank. When you flip the switch the motor turns and the unit moves, switching which tank the fuel is drawn from, and which fuel level sensor is connected to the gauge. This is why there are five wires on the harness. I could get some pictures if you want.
So just because the gauge doesn't switch doesn't mean the switch is bad. It just means that the unit inside the selector valve isn't moving like it is supposed to.
Originally Posted by RÖENTGEEP
Pics would be wonderful.
Bump, bump.
Old Dec 27, 2011 | 04:25 PM
cowmilker08's Avatar
cowmilker08
I try to get to it tomorrow.
Old Dec 27, 2011 | 07:15 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Thank you sir.
Old Dec 27, 2011 | 10:45 PM
newportman's Avatar
newportman
Forget about pics, I need the real thing, anybody have a good one laying around ?
smithm31
Apr 17, 2016 10:18 PM
newandoldford250
30
May 9, 2014 05:54 AM
AndysFords
Jun 6, 2007 11:50 AM
LesPaul
Electrical Systems/Wiring
Aug 26, 2003 11:05 PM
ptrill
Oct 8, 2002 08:07 PM
