Electrical issue
Old Dec 21, 2011 | 09:54 PM
dmanshane's Avatar
dmanshane
Electrical issue
Ok guys I got one I'm totally stumped 2000 f350 I have glow shift Gage's and they worked fine until I wired a relay in for spot lights so they turn off on lo beams and come on with high and have a switch to shut them off on high now on dim lights they are dim red color and when I go to bright they go blue and then I can change color but when I go to dim and back to bright the go back to blue this is with the switch on or off in the dash I used an existing light up switch that someone used before I had it for fog lights which I removed the light never worked in the switch I am stumped maybe faulty switch ??? In hook ground from switch see what happens ??? And use as normal switch ??
Old Dec 21, 2011 | 09:59 PM
timmyboy76's Avatar
timmyboy76
got 10 of them, and left the dimmer wire out of the equation...sorry i couldnt contribute to the problem though.
Old Dec 21, 2011 | 10:49 PM
dmanshane's Avatar
dmanshane
What u mean by 10 of what and dimmer wire what ???
Old Dec 21, 2011 | 10:51 PM
timmyboy76's Avatar
timmyboy76
10 glowshift gauges, and for the dimmer wire, i cut it at the gauge/connector. There was enough wire to deal with...lol
Old Dec 22, 2011 | 10:02 AM
dmanshane's Avatar
dmanshane
i had no idea there was a dimmer wire i guess there are two wires that go into one wire is the way i hooked it up
Old Dec 22, 2011 | 10:05 AM
timmyboy76's Avatar
timmyboy76
On my black tinted series, it was the orange wire, for the dimmer control...
red = hot
yellow = 12v switced
blk = grd
green = sensor , or depending if its the egt, think then its the blue and pink wires for probe
Wyoming150
1997 - 2003 F150
Mar 16, 2009 01:49 PM
bdb75
Feb 24, 2009 06:02 AM
speedrdr
May 4, 2007 12:19 AM
MuDDoG2011
Electrical Systems/Wiring
Jul 9, 2005 09:45 PM
FordPickup460
Nov 20, 2004 10:48 PM
