Trans shifter removal question
Old Dec 21, 2011 | 08:35 PM
Mad_max's Avatar
Mad_max
Im getting ready to take the cab off the frame tomorrow, Does the 4 speed shift shaft come off pretty easy and how?
Thanks in advace for the help !
Old Dec 21, 2011 | 08:47 PM
Ford_Six's Avatar
Ford_Six
Push down on the shifter and that stamped sheet metal collar, then rotate the collar about 90* counterclockwise, it'll pop right off.
Old Dec 21, 2011 | 09:08 PM
Mad_max's Avatar
Mad_max
Thanks for the fast reply, just tried it and it wont budge. i can feel a spring action when i just pull up on the shifter but it wont go down. Any ideas?
Old Dec 21, 2011 | 09:15 PM
Mad_max's Avatar
Mad_max
Old Dec 22, 2011 | 01:36 AM
Buzz44's Avatar
Buzz44
Slip a 1" or 1 1/4 box end wrench over the shift tower. Use the wrench as leverage to push down on the top of the collar lock and turn cc wise. It is a stout spring so it will take some muscle to push down and turn at the same time. You do not have to push or pull on the shifter to get the lock collar loose. I have read where some people are telling others to push down on the shifter too no need for that. One thing I recomend after you get the shift tower out get a good file and clean up berrs and ridges that may exsist from years of use. It will help get the lock collar reinstalled too. Should come out pretty easy once you get the right proceedure down. Good luck.
Old Dec 22, 2011 | 07:28 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
And make sure it is in neutral before removing. This will assist in getting it back in with shift forks correct.
Old Dec 22, 2011 | 07:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are TWO different 4 speeds used in these trucks, so there are TWO different methods for removing the shift lever retainer cap.
New Process 435 4 speed: The shift lever retainer cap (B8T-7220-D) has two notches, below the cap is a cone shaped retainer and coil spring.
The cap is retained in place by two (visible) pins that protrude from the shift tower.
To remove this cap, it must be pressed down and held down while turning it to remove it.
Some peeps are unaware, use pliers to remove it...which tears out one or both of the notches. Not pleasant!
Warner T-18 4 Speed: The shift lever retainer cap (8MTH-7220) is threaded, so it screws off/on.
Once the cap is removed, there are two roll pins (1/4" O.D. x 5/8" long)...that retain the shift lever in place.
Old Dec 22, 2011 | 09:36 AM
Mad_max's Avatar
Mad_max
Sounds simple enough, ill give it another go this morning.Thanks for the tips,much appreciated !
Old Dec 22, 2011 | 12:09 PM
Mad_max's Avatar
Mad_max
Originally Posted by Buzz44
Slip a 1" or 1 1/4 box end wrench over the shift tower. Use the wrench as leverage to push down on the top of the collar lock and turn cc wise. .
Boy using a wrench made it easy, came off in seconds! Thanks all for the help.Now on to the cab removal today.
Old Dec 22, 2011 | 12:25 PM
Buzz44's Avatar
Buzz44
Nice catch there gfw1985. Very important step not to leave out. Thanks.
Old Dec 22, 2011 | 05:20 PM
crazed87bronco's Avatar
crazed87bronco
I had to take my trans shifter off like you did on my np435 this summer in my 71 crew cab wish I knew about the wrench trick mine gave me trouble getting it out and just as bad putting it back together. Anyone have install tips?
Old Dec 22, 2011 | 06:41 PM
Buzz44's Avatar
Buzz44
Use the wrench and reverse the process of removal.
Martin Torres
Large Truck
Feb 16, 2019 10:03 PM
MLBaranowski
Aug 17, 2018 10:08 AM
masseysbronco
Jul 27, 2010 07:25 AM
girlwithatruck
Jun 14, 2010 10:29 PM
TheRoadVirus
Feb 23, 2008 07:59 PM
