66 C600 I6 Flywheel HELP!
I need Help! Long story short I have a 66 C600 with a 300 I6. the Ring gear is chewed up. (wrong starter) This old girls name is Grizzelda and she needs a ring gear 184 tooth. I have checked with all the locals tranny guys and no luck. The flywheel casting number is C6TE-6380 B. I need the following
Flywheel or ring gear.
Clutch assy.
This is our Bucket truck and we use it almost everyday. The sign installs are pilling up.
Help please.
Thanks
davemetituk@gmail.com
I have checked with all the locals tranny guys and no luck. The flywheel casting number is C6TE-6380 B. I need the following: Flywheel or ring gear / Clutch assy
C5AZ-6384-A .. 184T M/T Flywheel Ring Gear / Obsolete
Applications: 1965/72 F500/600 240 I-6 / 1965/72 C/F500/600 300 I-6 // 1965/67 F100/350 352 V8 3/4 M/T / 1968/76 F100/350 360/390 V8 3/4 M/T.
1970/77 LN600 300 I-6 / 1973/77 C600 300 I-6 / 1973/77 F500/750 300 I-6 (1978 and later 300 I-6 is 180T).
The clutch disc, pressure plate, throwout and pilot bearings will not be same as F100/350's.
1965/72 C500/600 300 I-6 could have either an 12" or 13" clutch / The 12" clutch was also used in 1965/72 F500/600 240/300 I-6's.
When we go bu application the starter does not fit in the bell housing hole.
The Auto starter fits but of cource that kills the ring gear.
Thanks
Dave
