Rear end
Old Dec 21, 2011 | 09:06 AM
ff1210's Avatar
ff1210
Rear end
Local rescue squad called me looking for a rear end for there 86 f350 drw crash truck. All they could tell me is it was a sterling rear with a 3.73 gear.
Can some tell me what would be a good compatible rear end for this truck, make,model,year,ext. The one that's in it they ran it low on oil and it post to trashed I haven't had time to look at it. Thanks for the help
Old Dec 21, 2011 | 09:40 AM
Boss351Bronco88's Avatar
Boss351Bronco88
The Sterling 10 1/4 came in the 85 and up F250s and F350s...85-97 should def be a direct bolt-in deal. F350s were the only ones that could have DRW. I think the newer trucks still use the Sterling, but the bolt pattern is different.
Old Dec 21, 2011 | 09:54 AM
greywynd's Avatar
greywynd
Being DRW limits what will fit as far as an entire axle. First thing you need to find out is if it was a cab and chassis (likely) or a pickup frame. Cab and chassis have a narrower frame, narrower spring perches, and if that's what it is, you will need to find another cab and chassis axle.
Old Dec 21, 2011 | 10:07 AM
ff1210's Avatar
ff1210
The bolt pattern should be 8/6.5mm and 98 to 05 should 8/170. Right?
Old Dec 21, 2011 | 11:17 AM
greywynd's Avatar
greywynd
Can't recall the numbers for the lugnut pattern, but that sounds about right.
Old Dec 21, 2011 | 02:46 PM
Coalroller's Avatar
Coalroller
yes thats right for the lug patterns
wasnt the drw a 10.5 though on the cab and chassis? im pry wrong just for some reason i thought it was
Old Dec 21, 2011 | 03:34 PM
ff1210's Avatar
ff1210
They post to let me know if its cab and chassis or not.
Old Dec 21, 2011 | 03:46 PM
ff1210's Avatar
ff1210
Old Dec 21, 2011 | 04:32 PM
Phy's Avatar
Phy
My 93 F350 is a cab & chassis, and has a 10.25.
If you were closer, and I had the right gears, I'd make you a deal. (I'm parting it out...)
Old Dec 21, 2011 | 05:40 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
they told you an incorrect gear ratio.the sterlings didn't get a 3.73 gear set option until the super duty era.major bummer i know lol.ford sure wised up about a bunch of options when building the 99+ super dutys.despite the dodge copy cat styling. oh i was so mad when they did that! (still not over it lol),they're alright.
she'll sport 3.55 or 4.10's.
Old Dec 21, 2011 | 05:53 PM
fellro86's Avatar
fellro86
It will be 8/6.5 Inches, not mm. The later is the mm spec. The later models are the 10.5 with the metric pattern as well. if you get in a bind finding parts, the internals are the same as the straight wheel, the difference is in the axle tubes. You can swap later parts in, not so much older into later. You will just have the speed sensor which you do not need for the 86.
Old Dec 24, 2011 | 02:05 AM
ke5adb's Avatar
ke5adb
I'd go with a late 92 - 97 ford rear, or find a dana 70 or 80 (preferably). The early ford 10.25 axle had a common problem for the yoke to wobble. The splines on the pinion were revised in 92 and made about a 1/4" longer. The bad thing is when you tighten the pinion nut down and start pulling the pinion away from the ring gear because of the crush sleeve. It's better to run it loose until you can find a replacement. If it is a chassis cab, the frame width is 34". If it is a chassis cab, you can use an axle from a chassis cab or a pickup (move spring mounting pads in), but not the other way around. The ford 10.25 axles were offered with a 3.08, 3.55, and a 4.11 ratio. If you find a dana rear under a ford, the u-joint should be the same size.
Dean6586
Sep 7, 2015 07:54 PM
rustyescott
19
Jan 26, 2013 05:06 AM
mrblonde108
Jun 18, 2010 11:41 PM
bshep
Feb 5, 2008 06:16 PM
rabidranger
Jan 26, 2002 06:55 PM
