06 F250@ 70ish missing
Old Dec 16, 2011 | 11:51 PM
Muddyballs's Avatar
Muddyballs
Bought the truck 4 months ago and love it. The last month or so on the highway around 70mph it would miss like it was not getting fuel. Well Tuesday it was acting up really bad I took it to a diesel mechanic by my house not the Ford House, and he put it on the computer then drove it and said it was my FICM. Well $1100 later I still have the same problem.
This is my first diesel and I know nothing about car in general and less about diesels. Here is a little info on the truck Crew Cab,4X4,intake,Dual 4" exhaust, EGR delete,SCT Programmer (Flash).
I was getting around 22mpg before this problem started, and after he replaced my FICM best I am getting is 18.
Thanks in advance for any help.
Old Dec 17, 2011 | 09:34 AM
dlibson's Avatar
dlibson
You could have a few issues. Did he say why it was the ficm? Are you bringing it back to them? If you paid $1100 and it's not better, then they need to make it right.
My first thought however, is a bad injector.
Old Dec 17, 2011 | 11:00 AM
BLADE35's Avatar
BLADE35
That sucks
sounds like an injector or injector harness
scan for codes see if that dials you into what cylinder
you could have gone thru the ficm and had it repaired for 250-350 bucks stick around and learn about you truck
and welcome to FTE
Old Dec 17, 2011 | 12:07 PM
69cj's Avatar
69cj
When were the fuel filters last changed and are they OEM?
Old Dec 17, 2011 | 02:49 PM
Muddyballs's Avatar
Muddyballs
Thanks for the replys
I learned that about the FICM the night I had it done. I live in Keller an read from a couple other guys that had it rebuilt by a guy in Haltom City that gives a life time warranty on his work. I really need the truck for work and was just trying to avoid any down time.
I had the filters changed 5000 miles ago at Kwik Kar. Im not sure which ones they used.
I thought of something else, I don't know if this makes a difference but the first time I ever noticed this was after my hose from my intercooler blow off the turbo.
Thanks again in advance for any advice.
I am going to attempt to change my fuel filters on my own today. Wish me Luck. I'm a trim carpenter and not at all a mechanic.
Old Dec 17, 2011 | 03:23 PM
dlibson's Avatar
dlibson
Make sure to use OEM Ford Filters. It's not a hard job to do, just no fun underneath...
Did the hose blow off randomly, or did you have it off for some other reason?
Old Dec 17, 2011 | 05:07 PM
Muddyballs's Avatar
Muddyballs
Dlibson
He put it on his computer and said it was only showing 38 to 40 amps at the FICM.
The hose blow off when I was trying to pass another truck, I stuck my foot in it and it blow off started blowing black smoke and I lost power.
Old Dec 17, 2011 | 05:27 PM
69cj's Avatar
69cj
That would be volts, not amps and the brand of filters is critical on a 6.0. Not saying that is your problem but if the filters are restricting the fuel you can take out the injectors. The 6.0 is one of the engines that needs all OEM filters.
Old Dec 17, 2011 | 05:31 PM
BLADE35's Avatar
BLADE35
sounds like the turbo maybe sticking and need cleaning
If the truck ever sits for awhile the unisone ring that controls the veins rusts and then the veins sticck
when the boot popped off the intake air was cut off and began to overfuel
this might be the studder IDK but all you can do is clean turbo and see how it goes after that
Old Dec 17, 2011 | 05:58 PM
Muddyballs's Avatar
Muddyballs
Blade35
Is cleaning the turbo something I should attempt myself? Or do I need to take it to someone?
Old Dec 17, 2011 | 07:06 PM
BLADE35's Avatar
BLADE35
IDK Depends on your wrenching ability
heres a good writeup on it although its a compleate turbo rebuild its what you will be dealing with
https://www.ford-trucks.com/forums/1...ml#post9449262
read thru it ^^^^^^^^^^^^
but basic tools and stuff so its possible for a DIYer
jleworthy
Apr 26, 2017 03:24 AM
///M Puller
Sep 9, 2010 10:20 AM
newportimports
Oct 28, 2008 10:43 AM
2003 6.0
Aug 27, 2006 11:48 PM
