Yes Sir
U-joint is done, your stub axle(the outside end) is supported by a needle bearing located inside the spindle and it also needs to be replaced. JBG has Spicer u-joints($30.ea.) and spindle bearing/seal kit(10.ea.) for a Dana44. This is the time to check the rest of your front end so you only have to tear it down once.
Tony
The reason its like this is cos my "friend" locked the hub on that side when it was on the rack and I didn't realize it was locked until I went to lock it to go wheelin 150 freeway miles later.
I've got a spicer u joint and needle bearing for the inner spindle for that side. Do you think the wheel bearings on that side need to be replaced? They're only 4,000 miles old
