Flashing theft light?
Old Dec 15, 2011 | 12:21 AM
Pitcrw6's Avatar
Pitcrw6
What is the flashing theft light for if you dont have a alarm sys on the Ex? I never put an alarm sys on and I dont think it comes from the factory with an alarm sys. I think of the flashing light just draining the batt after a week. Someone please explain this to me.
Old Dec 15, 2011 | 01:00 AM
jh818's Avatar
jh818
That is your PATS system. Only keys with the RFID chip inside will be able to start the engine.
Old Dec 15, 2011 | 03:19 AM
Pitcrw6's Avatar
Pitcrw6
Wow... I didnt know that, so thats why my F350 doesnt have the light and a regular key and my Ex has the chip in the key. Thanks, always learning something new one here every day.
Old Dec 15, 2011 | 10:29 AM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
So don't lose your keys...
Old Dec 15, 2011 | 02:24 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Or go swimming with them in your pocket.
Old Dec 15, 2011 | 02:56 PM
jh818's Avatar
jh818
What I've heard people do is put the chip part of their key near the ignition on the steering column and just cut regular plain keys to start their Ex. This way, you lose a key, you can easily cut another for a buck at Wally world. You can swim with the regular key in your pocket. The drawback is you can just stick something in the lock cylinder and turn it and the truck will start.
Old Dec 15, 2011 | 02:59 PM
TXtinct's Avatar
TXtinct
That's kind of how they set up the remote starter on these trucks.
Old Dec 15, 2011 | 06:00 PM
MikeRizz's Avatar
MikeRizz
When I bought my most recent X the dealer " thought " it had a remote start, but couldn't get it to work. After I got it home I climbed under the dash and found the control box, which was indeed a remote start. I made sure it had power and started playing with the key fob to try and figure out the start procedure ( that took a while but I got it ). So does that box essentially have a PATS key inside?
Old Dec 15, 2011 | 06:31 PM
RACERX7775's Avatar
RACERX7775
When i had my viper 5902 installed, it is another module for the PATS bypass system. There is no need to have a cutoff key under the dash. Cause' if you do that, someone can chop the column and start the truck and drive away. When you have the module for the bypass, that wont happen, the alarm will go off and they still wont be able to drive away that easily. Either way, if they want it bad enough, they are gonna get it. Thought I'd share that with those who want a remote start and dont want to chop a good key apart.
Excursino Limousine
May 19, 2013 06:37 AM
primer85f150
1983 - 2012 Ranger & B-Series
May 4, 2006 02:44 PM
stutterstan
Dec 30, 2004 07:08 PM
mwm
Electrical Systems/Wiring
Apr 25, 2004 03:59 PM
winsco
Nov 24, 2002 06:43 AM
