Steering column
Old Dec 16, 2011 | 09:47 AM
Skier041's Avatar
Skier041
thanx a lot....ill go check that
Old Dec 16, 2011 | 04:58 PM
Talyn's Avatar
Talyn
Originally Posted by Skier041
wow i didnt know that...i was told they are all interchangeable....everything hooked up the same except for the airbag
Yeah, the 150 column is different.
Midnight Mods: Steering Wheel Swap/Mod
Im actually familiar with this. I attempted to do it myself.
Old Dec 16, 2011 | 05:00 PM
Talyn's Avatar
Talyn
Originally Posted by DIYMechanic
So just to confirm, you can turn the key on and the dash lights up, all the gauges come on, but when you turn the key to the start position, nothing happens? Just for S&G's I would have a helper turn the key while you check for voltage on the small (coil) wire on the starter solenoid on the passenger side fender. If you're getting voltage to the solenoid when you turn the key, your switch is fine, you just need a new solenoid.
Thats a good idea.
The wiring was different on mine, so if he got it to work, then thats cool.
NebraskaBorn
Jan 21, 2015 03:38 PM
Doods54
18
Apr 29, 2014 09:37 PM
lazerf250
Oct 21, 2009 10:32 PM
manger
Mar 8, 2009 07:54 PM
JDJINTX
Nov 23, 2006 08:34 PM
