That’s it! I’m done with this truck! Someone just come and tow this heap way from me!
Geeezzzz guy’s….. now you all have me not sleeping at night. Pleeeeeze no more posts about how bad this thing is. It just has some issues to deal with like all the other trucks on this forum do or did at one time. This truck is in very decent condition still. Despite the frame issues you see in the rear, that rear is still VERY solid back there as a whole. Just need to cut out and replace a few areas. What is the big deal with that?
The frame behind the one spring hanger I admit is pretty bad, and I have not figured how best to replace that area. Until I have it off (after the first of the year) I really won’t be able to assess it. I purchased a pneumatic needle scaler last night and I am anxious to run it over the frame back there. This should do pretty good job knocking off the old flaking coating and surface rust, which I think is making the frame look worse than it is. I hope that’s the case anyhow…….
This isn’t work for me! This has already been the most fun I have had in a long time. Seriously. And so long as it remains fun, I’ll be good. I don’t NEED this truck. I WANT this truck. And maybe that’s the difference in committing to a project like this.
All the problems you have with this truck are the same as I had with mine as far as rust. These guys just don't get what we have to deal with in the north east. And if you haven't been zapped by a good looking truck that turned out to be a mess when you took it apart, then you haven't really tested your skills! This is a test of your manhood, a battle of wills, and there is nothing more rewarding than fixing up something that everyone else would have gave up on. Especially when it turns out nice. So I aplaud your bravery, and say... once more into the breach dear friend!
If you can't spot what a lifter is I suggest you do NOT put this engine back together. I would recommend replacing all the lifters and cam anyway. They are common wear items like an oil pump. You wouldn't rebuild an engine and use the stock timing chain and oil pump, don't use the same cam and lifters. (I'm **** about this stuff) Besides, it's a great opportunity to bump up performance with a little bigger cam. I've built dozens and dozens of engines and I have yet to put used lifters in an engine.
You need to do some hard core research on how an engine works, or give the pieces to a machine shop and tell them to call you when it's done. There's too many pieces in that engine that can turn a good running engine in to a grenade if you don't know what you're doing. (and the fact that you were hammering on a lifter trying to "seat it" means you have a lot to learn.)
Seriously, I'm not trying to be negative here, I just don't want you to waste a lot of time and money by doing it wrong. There's clearances in there that are into the single digit thousandth's of an inch. ...and it has to be dead on ***** accurate or the engine can throw a rod in short order.
Nah…you’re right Quake. That was such a stupid miss by me on that one. I know better…I really do.
I feel real bad for anyone following along that knows even less than me that they witnessed that episode. So my apologies to you guy’s on that one. I’m not that proud of a man and know when to admit defeat. I didn’t actually try to drive them, I just knew they weren’t pushing back down easily. But yup, when I actually put my brain into gear and THINK, it all comes together.
With this motor, especially since it is already .040 over, I am not likely to want to truly rebuild it ever, or turn it into a 400, so I am less concerned that I will be reusing a lot of parts when it goes back together. I just want to use it for my “trial” period of the truck to see what a 351m “feels” like. So I probably will still take it down to a bare block, clean it out good, (no sandblasting, milling, or any other true machine operations) and just put it back together properly. I guess at a minimum that means new rings, seals, and gaskets. Not looking to replace crank or cam bearings, cam, lifters, etc.
I don't know if you tried this or not but I used to grind the rivet head smooth and then punch it out.
That's what I origianlly did back a few pages.
Originally Posted by justforkicks
i had a few stubborn rivets when i was doing my shackle flip. i just kept on beating the hell outta them until they just popped out. one took me a good half hour. heating the metal around the rivet should expand it enough to get some progress.
Gotta get at it some more I guess....
Originally Posted by kevin316
that motor looks clean, how long has it been since it was rebuilt?
Another trick with the rivets is to use a large drill bit, smaller than the rivet, and drill about 3/4 of the way through. Now get a punch that fits loose in the hole a drive away.
No idea on the previouse rebuild.
That is a great idea on the rivets. I might have to try that next.
bdawg...haven't heard from you, ..still wanting those frame sections..OR..maybe a whole frame and a complete 351M w/ it??
Lost, I really won't have a chance to mark out and truely figure out what I would need until I have all the parts back there taken off....so if it is something you are looking to get rid of and out of your hair, then dont wait for me. If you can hang on another month or so, than that would be cool too, but do what you gotta do.
I'm DEFINITLY keeping this original frame as all the numbers are matching to original.
The debris sitting in the valley pan I am pretty certain came from the vally pan itself. You can see (green arrows) that this area had deteriorated through at all four corners of the heads.
Ewww really needs a good cleaning I know you didnt want to much done to it but the whole block might need to get a bath. Those corners are part of your coolant flow and those are completely blocked.
just checking in/following up..pm me your email address and I can send you some pics of what I have and go from there ..when you're ready, for now it is not in my way...
remember I also have some spare engines available too..
Sorry for the but can you give us a little info on that barn/shop/garage you have. Is that a post & beam? Did you buy it prefab or just build it that way.
Thanks for the interest in the barn. Here is a pic of me in front of it. Yes, it is post and beam. Not a prefab really. I designed out what I wanted (how many options are there really) and the lumber mill engineered it with plans and fabed up all the timber. Then a different contractor erected it. Had to make all the joints on site. Also put a standing seam metal roof on it.
Seriously though....I'm a little reserved at letting the whole world into my house without knowing them. You know what I mean?
I know what you mean but that is a nice barn you have.
