I have a 03 navi with 5.4 , had misfire code so replaced the cop and plugs and all injectors, still have rough idle with no codes now.
It seems to be fine off idle but if I run the throttle under the hood I can feel a vibration at different rpms, cleaned the maf and replaced some vac lines also with no luck - any ideas?
iof is a typo i meant off not oif. I have fat fingers!!LOL
What you do is you pour about 1/3-1/2 a can of Sea foam into the vac line. I used the vac line from the brake booster, it was the easiest to use. You can go to the SeaFoam website and they explain exactly how to do it. Maybe it will help. I have done this to my Nav. a few times and it seems to help with a rough idle.
