03 Navi Rough Idle
Old Nov 25, 2011 | 02:15 PM
RKR's Avatar
RKR
03 Navi Rough Idle
Hi I have a 03 Navigator 5.4 w/125k and the engine light came on P0308 misfire cylinder 8, it had been running rough at idle only! and somtimes is hard to start after being warm. Replaced the COP and plug on #8 and reset the codes, now a day later the same code is showing and is still rough on idle, also when its periodicly hard to start it smells like gas coming from the exhaust when it starts- Any ideas? Mabye fuel injector?
Thanks
I also pulled the vaccum line from the FPR and didnt see any fuel.
Old Nov 25, 2011 | 04:36 PM
alloro's Avatar
alloro
Originally Posted by RKR
Any ideas? Maybe fuel injector?
Yes, it sounds like the #8 fuel injector is leaking.
Old Nov 25, 2011 | 04:45 PM
RKR's Avatar
RKR
Is it worth doing an ohm test on that injector? Also would an ohm test even tell if it was leaking?
I'm guessing I'd have to remove the intake manifold to get at the injector or is it possible without.
Old Nov 25, 2011 | 04:51 PM
RKR's Avatar
RKR
Would a leaking injector throw the P0308 misfire code?
Old Nov 25, 2011 | 06:11 PM
dlibson's Avatar
dlibson
Yes, anything that causes a miss in a cylinder will throw a code.
I would agree the injector is likely leaking. There are a couple ways to test for it. Run it, let it get warm. Then let it sit for a while. Pull the plug, and look in the cylinder, if it's wet you know. If you can't get an angle to see. Have someone crank it over and watch and see if fuel sprays out. Please, don't be right over the hole though... (I know, but if I don't say it someone will whine about it)
Other thing is to put a fuel pressure gauge on it. Turn the key on, it will build pressure. Shut it off. If it bleeds the pressure down, that is a possible sign of a leaking injector.
Old Nov 26, 2011 | 07:54 AM
Knukle Head's Avatar
Knukle Head
Try the vacum tube elbow ... it causes all kinds of codes ..
Old Nov 26, 2011 | 09:07 AM
RKR's Avatar
RKR
Which vacuum elbow is that
Old Nov 26, 2011 | 09:15 AM
dlibson's Avatar
dlibson
He means the one on the back of the intake. Its the pcv tube. However, that would provide a random cylinder misfire, and lean codes. Not a cylinder specific code.
Old Nov 26, 2011 | 09:41 AM
RKR's Avatar
RKR
Ok, ill do the fuel pressure test and see if it leaks down.
Do you have to remove the intake manifold to access the injectors?
Codeman894
Apr 29, 2017 02:19 PM
kornfanjoe
Jan 16, 2015 09:36 AM
sosuok
2004 - 2008 F150
May 17, 2014 12:02 PM
Psygnosis
Aug 21, 2013 07:10 PM
buckford
Jan 22, 2004 08:41 AM
