another 2003 7.3 no start
Old Dec 13, 2011 | 01:02 PM
DPressley's Avatar
DPressley
I have a 2003 7.3 with no start issues. i let it sit over night and was able to start it with a little help from starting fluid. while hooked up to a snap on scanner i watched the ICP at idle and it started off at 500+- psi and slowly dropped to about 400 and tried to die. i then gave it a little throttle and it will run at higher rpms. wondering if it is my ICP, IPR, or if it could be my HPOP. One other thing. At crank my ICP pressure reads 0 and my sensor looks a little wet. could this be my problem. every time my buddy sees a problem with icp he always assume HPOP. trying to start off on the cheaper side haha
Old Dec 13, 2011 | 01:18 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
If there is oil in the plug connection on the ICP, it would be a good idea to change it. Have you disconnected the ICP and started the truck to see if it will idle good?
Old Dec 13, 2011 | 01:58 PM
DPressley's Avatar
DPressley
Thanks for the quick reply. I have disconnected the sensor. It stumbled a little and then it cleared but still wouldn't keep my truck running when I let off the throttle. I reckon I can start with the ICP sensor.
Old Dec 13, 2011 | 02:01 PM
DPressley's Avatar
DPressley
would that cause my pressure to fall off the way it does?
Old Dec 13, 2011 | 02:23 PM
miller_feed
Can you do a little data loging and see what the duty cycle is doing as the psi goes down?
Old Dec 13, 2011 | 02:46 PM
DPressley's Avatar
DPressley
At 1500+- rpms the ICP is at 700+- the IPR is at around 17% and when it dies it shows 15%
Old Dec 13, 2011 | 06:17 PM
F350-6's Avatar
F350-6
While you're cranking and showing 0 psi on the ICP, is the IPR % climbing or maxing out, or does it stay low? As you crank, the IPR % should increase to over 60% if it's not starting.
You're saying that as ICP drops off and the truck stalls, the IPR % does not increase any? Does the IPR % change or act any different if you unplug the ICP sensor?
Also, I'd try to avoid the starting fluid. It can be catastrophic on a diesel. If you must use it, at least disable the glow plug system. Welcome to FTE.
Old Dec 13, 2011 | 07:10 PM
DPressley's Avatar
DPressley
Thanks for all the info. I will check on it again in the a.m. If my ipr doesn't go over 60%, what would that indicate
Old Dec 13, 2011 | 07:30 PM
F350-6's Avatar
F350-6
There's no magic bullet, but it would give us a direction to go in with troubleshooting.
Old Dec 14, 2011 | 10:37 AM
trekbasso's Avatar
trekbasso
Sorry to jump in but I just started having very similar symptoms, will start but idled very rough and noisy. Cleared up after a few minutes.
I know the ICP might be an issue, Ford wants 185!! Really.
Thanks. Tom.
01 F250 7.3 203,000. 60 degress in Houston this morning.(not really a cold start)
Old Dec 14, 2011 | 10:01 PM
DPressley's Avatar
DPressley
Changed out my HPOP and ipr and icp with one my buddy had laying around. Still no start and read a P1211. Swapped the IPR back out and cleared codes and still no start. My duty cycle was right at 65%. Cranked for about 15 seconds and my ipr finally climbed to 200. Any chance my CPS may be causing any of this with no codes? This is the first time I've been so stumped that I am ready to put a match to it. I'm sorry frustrated. My truck is my paycheck.
Old Dec 15, 2011 | 11:45 AM
vetklr's Avatar
vetklr
I'm having the same problem with my truck but once you get it started ( with a rag with gas on it ) it will run all day but if you cut it off it will not restart
Old Dec 15, 2011 | 12:30 PM
DPressley's Avatar
DPressley
That's how mine was before this issue
Old Dec 15, 2011 | 04:32 PM
vetklr's Avatar
vetklr
Is it possible that the main engine oil pump is weak ?
tberg725
May 19, 2018 07:53 AM
Racecar_Dave
Dec 28, 2017 02:20 PM
HayTruck
16
Sep 29, 2015 10:59 PM
matconger
Jun 22, 2010 09:28 AM
Forced347sn95
Sep 29, 2008 05:03 PM
