New to this forum, but not new to the site, I am getting a 1993 Ford Bronco tomorrow, and it has the 351 engine in it. I am not that familiar with the small block Fords as I previously only owned a four banger, and the 460. So My question is, which 351 is in the Bronco, the "M" or the Windsor? Thanks in advance.
thats funny! just get some air to it and she will quit weezing. windsor run good also but the canted valve is nice on the 335series clevelands. windors run but if you can clean up ports and take out the bump in engine really help on these heads. she'll run and good luck. engine is a air pump is all you need to know.how much air you move in and out efficiently is the trick!
