351 plus .030 bore = ??cid
Old Feb 13, 2008 | 02:10 AM
honkytonk's Avatar
honkytonk
just had my 351 machined to .030 and was wondering what the new cubic inches were gonna be? Ive searched this forum for half an hour and cant seem to find the answer.
thnks
Old Feb 13, 2008 | 02:55 AM
bucks77ford's Avatar
bucks77ford
I was thinking it would be 393 CID. Use the formula:
Bore x Bore x stroke x # of cylinders x .7854 = engine displacment
4.030 x 4.030 x 3.850 x 8 x .7854 = 393 (rounded)
Old Feb 13, 2008 | 05:57 AM
fastfarmer's Avatar
fastfarmer
351 has 3.5 stroke. 3.030 X 3.030 X 3.5 X 8 X .7854 = 357 cu in
Old Feb 13, 2008 | 06:02 AM
brownfoot's Avatar
brownfoot
something's wrong with your formula
4 x 4 x 3.85 x 8 x.7854= 387 cu. in........................not 351??????
Old Feb 13, 2008 | 07:49 AM
fastfarmer's Avatar
fastfarmer
My post above should read 4.030 X 4.030 X 3.5 X 8 X .7854 = 357 cu in.
Old Feb 13, 2008 | 11:35 AM
pdqford's Avatar
pdqford
Common guys - volume of a cylinder is pie times radius squared times height.
4" bore has a radius of 2", pie is 3.1416.
So one cylinder = 3.1416 times 2" times 2" times 3.5 = 43.98 cu in
times 8 cylinders = 351.86 cu in.
A .030" over bore would change the radius to 2.015".
So one rebored cylinder would be 3.1416 times 2.015" time 2.015" times 3.5" stroke = 44.64 cu in. times 8 cylinders = 357.16 cu. in. total displacement.
Old Feb 13, 2008 | 11:44 AM
LxMan1's Avatar
LxMan1
Commonly called a 358.
Old Feb 13, 2008 | 11:46 AM
fastfarmer's Avatar
fastfarmer
Yup. 357 cu in.
Old Feb 13, 2008 | 04:45 PM
bucks77ford
I'm not much a motor guru, and my info was just based on a search from the internet and I guess I was wrong. So much for searching. My bad.
Old Feb 13, 2008 | 05:17 PM
whd507's Avatar
whd507
better to try and be wrong, than not to try...
at least with small stuff like this...
