351?
Old Jan 13, 2004 | 12:06 PM
JCastellaw's Avatar
JCastellaw
351?
My dad has a 79' F-150 Rabger XLT with a 351. I have a 74' Bronco with a Blown up 302 (Cracked Block) How can I tell if the 351 is a windsor and if it will fit in the Bronco?
Old Jan 13, 2004 | 01:38 PM
Kemicalburns's Avatar
Kemicalburns
it wont be a windsor , they only came with either the 351m or 400m. check out your local wrecking yard for a motor would be your best bet
good luck
Old Jan 13, 2004 | 07:26 PM
WALJON's Avatar
WALJON
I agree 302,s are a dime a dozen .
Old Jan 13, 2004 | 08:31 PM
JCastellaw's Avatar
JCastellaw
I would like a windsor
Old Jan 14, 2004 | 09:34 AM
Kemicalburns
I got a complete 351 motor out of a 95f250 for $800 bucks. so i could swap out my 302. just keep your heads off the 302 and find a 351 block, replace the bearings if need be put it together it will bolt right up to your tranny and be more fun then a 302 for sure.
late
Old Jan 14, 2004 | 10:09 AM
JCastellaw's Avatar
JCastellaw
what's the diffrence between a windsor and a modified or cleveland
Old Jan 14, 2004 | 11:03 AM
Kemicalburns
block, heads. the modified uses a big block bolt pattern. they are a torquey motor but hard to find aftermarket for them . havent been made since early 80's. Cleveland is similar to windsor but had different heads, dont know much more then that but they stopped being produced in the early 70's.
some one will add some info here im sure
late
BroncoMonster82
1978 - 1996 Big Bronco
Jul 2, 2012 08:00 PM
ftwosh
Feb 28, 2011 09:44 PM
torque head
Feb 26, 2011 10:52 PM
mnm1997
Computer Chips & Tuners
May 4, 2001 02:57 PM
93bronco
Dec 23, 2000 12:25 AM
