Servicing an E4OD
Old Dec 11, 2011 | 10:50 AM
Scaper's Avatar
Scaper
Question Servicing an E4OD
Ok so today I want to service my E4OD trans and I just wanted to make sure (because it is my first time) that I wont run in to the unexpected. First I drop the pan by removing all the bolts on the long sides of the pan, then remove all but two bolts on the short ends... Once that is off I want to drain the torque converter right? What have you guys been using for turning the flywheel? Once that has been drained I then remove old filter and install new one. The I clean the surfaces for remounting the pan with a new gasket. Tighten her up, and spry down with brake clean so is easier to check for leaks. Sound right?
Old Dec 11, 2011 | 10:54 AM
Scaper's Avatar
Scaper
Oh yeah and does 14.8Liters sound right for the amount of fluid? Its 2WD. Also is there any specific ATF I should use? Thanks guys!
Old Dec 11, 2011 | 01:06 PM
Scaper's Avatar
Scaper
I cannot find a single flywheel turning tool at any of the shops around here. Does anyone have any tricks for spinning the flywheel? If not I can get one tomorrow.
Old Dec 11, 2011 | 01:27 PM
Lazy K's Avatar
Lazy K
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles Here is a link to a good method.
If you do decide you want to drain the converter then you could rig a remote starter wire (from the fender mounted relay) or get a helper to jag it over on the starter (having disconnected the FSS wire).
Old Dec 11, 2011 | 01:41 PM
LSO1123's Avatar
LSO1123
I disconnected the starter wire from the relay and hooked up two wires to the relay and ran them down under the truck. Layer under the truck and watched the converter while I touched the wires together. Worked great. Make sure your key is off or, probably a good idea to unplug wires to FSS, just to make sure it don't start.
Scaper's Avatar
Scaper
Thanks for the great link! Thats everything I need to know
Old Dec 11, 2011 | 02:32 PM
tecgod13's Avatar
tecgod13
You can also put a socket on the crank bolt up front and use that to turn the engine and thus the flywheel. Little more manual work, but it will work and allow you to turn it exactly where you want.
Old Dec 11, 2011 | 02:41 PM
halaferd's Avatar
halaferd
I have always been alone and just used a large flathead screwdriver or pry bar to turn the flywheel. Just brace it against the edge of the bell housing and catch the teeth with the flat end of you tool. That way your under it to see where everything is and you don't add any stress to the starter.
Just me tho
El Camino Man
Jun 26, 2012 12:56 PM
wayneF250
Apr 17, 2008 10:10 PM
Bruiser 1
Nov 25, 2006 06:15 PM
Point Blank
Jun 28, 2005 07:28 AM
T/A Man
Sep 20, 2003 01:09 AM
