compressor wheel
Old Dec 11, 2011 | 03:17 PM
dyhrdford's Avatar
dyhrdford
I understand the benefits of using this "fooler" you guys are referring to, but what I dont understand is the possible ramifications of using it. My thinking is if the PCM is defueling, the turbo is spinning at, for ease of explaination 95,000 rpm. If you make the PCM believe there isn't as much boost then it throws more fuel to it, you end up spinning the turbo at 115,000 rpm's, thus making more boost than the 23 PSI. Now, if the turbo isn't designed to be able to handle the added speed the chance of it scattering is greatly increased. Does this make sense to anybody else?? Thinking outside the taco shell...
Aaron
Old Dec 11, 2011 | 03:27 PM
Bonanza35's Avatar
Bonanza35
Aaron
Aaron you got a hold of it. With a tuner everybody wants more tork and HP at different times in the power curve. Now to get that you don't want your engine defueling all the time. Now some tunes build in defueling when the EGT's go to high like in towing, and some don't therefore the gauges you need to watch. With a tuner you can make your stock turbo hit 30psi which is not good for it. Thats why people in stall other turbos. The 38R is a direct replacement without any extra work. Not all like that turbo and use others. Anyway more air usually means lower EGT's with correct tuning, still need gauges. My 2cents, Chet
Old Dec 11, 2011 | 04:44 PM
HD Rider's Avatar
HD Rider
Originally Posted by Riffraff Performance
Shipping on Tuesday
I
m a happy camper now. You the man!
Old Dec 11, 2011 | 04:46 PM
HD Rider's Avatar
HD Rider
To use a blowoff type valve successfully in the map line, you need a orfice between the intake and the blowoff valve. That way it is not blowing off all your manifold pressure, just enough to trick the map sensor.
Old Dec 11, 2011 | 04:48 PM
dmanshane's Avatar
dmanshane
ts 6 pos chip stock high idle 50 75 100 140 stock turbo ported ats housing i am wanting to get a 38r but cant afford it right now
Old Dec 11, 2011 | 08:01 PM
dyhrdford's Avatar
dyhrdford
Chet, thanks for the explaination. So using this fooler is just a more economic way to achive the higher boost pressure levels and not throw codes and/or defuel rather than installing a new turbo?
Old Dec 11, 2011 | 08:24 PM
dmanshane's Avatar
dmanshane
if i am not mistaken it will still defule with a 38R if u dont have a fooler the 38R is on my to do list but i did buy a different type of fooler from riff raff heres a link Riffraff Diesel: OCR - Overboost Code Regulator this does not bleed off boost it just regulates the pressure to the mapp sensor which i believe is a heck of a lot better than just blowing good boost pressure off to the atmosphere and think when i do buy the 38 R it will be very useful
Old Dec 12, 2011 | 12:01 AM
Bonanza35's Avatar
Bonanza35
Smile
Well with stock tuning your not going to see extra high boost levels except in extreme conditions like towing heavy up a hill. So yes and no. The tuner will ask for higher boost levels to go with the new fuel curves being used. More boost, fuel, HP and hopefully wider tork range. Without the fooler the PCM will defuel before you can get the hole advantage out of the tuner. At least a custom tuner.
Chet
benjibob25
Nov 22, 2008 09:02 AM
griff64
Feb 10, 2008 11:29 AM
crack
16
Oct 6, 2006 08:29 AM
marvinlong
Apr 19, 2006 09:16 PM
Barnknee
Apr 1, 2003 02:31 PM
