Ive got a 2000 with a 6spd and I recently put on the 6637 and drove it a few hundred miles. and I just got in my 6.5 lift and 37s, and straight piped my truck, so I was out driving and seeing how everything felt, and when I got into 6th..at about 110km/h on the speedo it started makin this shh shhh shh noise and then I let off and it made the big TH TH TH like a turboed up mustang. I unhooked my wastegate and it still did it...I havea super chips in on the tow setting..so am I gettin a boost leak is it becasue of the chip, is this surge...whats the dealio?
sorry for the length
edit- I heard it one time before the straight pipe..but not as bad
Ive heard mixed reviews on the turbo air guide. Some say it makes a difference, some say it doesnt and is a lot of money for not a huge difference.
What about high performance wastegate actuator? Any body running one of those? Sorry I just ordered a boost tube, MAP line T and Overboost annihilator...maybe changing the wastegate would make a difference.
Nice call mueckster! Only $403 at Xtreme or $1500 for a Ball Bearing
Wastegate does nothing for surge. I put a Banks Big Head on my stock turbo with no change in surge. However, the BB turbo sure took care of it.
As far as the TAG goes, I'm not wasting my money. All these mods to open up the intake and breathe in more air, then stick a restriction in there just defeats the purpose. Besides, surge is caused when the turbo is providing more air than the engine uses, and that air has to back out somewhere. I don't see how a TAG unit could change that effect. Only a different wheel design, different compressor, or larger turbine housing can affect the amount of boost enough at the rpm level to eliminate surge.
I purchased a T-61 direct replacement turbo with a 92mm exhaust side with an EBPV elimation kit for $1200 bucks. It's comparable to the turbonetics replacement turbo but for less money. The BB turbo is nice but it's not at all necessary for these trucks, especially if you're towing. My truck pulls like a freight train with it, and it eliminated surge completely.
how long does it take to instal the WW...an hour or 2?
Around 2 hours.
I have the WW and it completely cured my turbo stalling when towing. The only time it will stall now is if I push it hard enough to drive the EGT to 1300 and above. And I don't make a habit of that practice so for me it's a complete solution.
