Blown 7.3 Turbo Seal
Old Dec 9, 2011 | 09:23 PM
let_the_coal_roll's Avatar
let_the_coal_roll
  • I have a 2000 f350 with about 175000 miles on it. it has a 6 position switch, and s&b intake and stacks. i noticed yesterday that it was blowing alot of white smoke. i thought maybe it was alown head gasket but its not low on coolant. i saw alot of oil dripping out the bottom of the stacks. i looked at the turbo and theres alot of oil under it. Any ideas??? thanks
Old Dec 9, 2011 | 10:01 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Probably the shaft seal on the turbine side. Are you running a CCV delete?
Old Dec 9, 2011 | 11:37 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Or the o rings in the pedestal or under the turbo. My oil x over came loose on a turbo swap n it filled the valley and ran down the back of the engine.
Old Dec 10, 2011 | 12:06 AM
mongo75's Avatar
mongo75
If your blowing white/blue smoke, it's the turbo internal seal. Order a turbo rebuild kit (Ron's Turbo Shop on ebay) one the bolts and clamps are sprayed with a rust buster type of fluid (let sit for a good half hour, you can have the turbo out in about an hour, and rebuilt and back in in less than 4 hours tops. I got it down to about 2.5 hrs LOL....
Old Dec 10, 2011 | 12:14 AM
Bonanza35's Avatar
Bonanza35
Clay at Riffraff diesel and set you up with the rebuild kit. Not a bad job at all.
Chet
Old Dec 10, 2011 | 01:35 AM
duck fan's Avatar
duck fan
Because racetruck
Order a kit from Riffraff and call them if you have any questions, they will walk you through rebuild. Don't mess with eBay hacks that sell crap parts for way to much. If they were a good store they wouldn't waste their time on eBay. Not to mention Riffraff is a avid forum sponsor.
Riffraff Diesel Performance Parts: - Turbo Rebuild Kits
Old Jan 1, 2012 | 07:15 PM
clangley's Avatar
clangley
Hello Guys. Sorry for the first time post But this is kinda urgent.. Lol
Ive got a '99 250 4x4 completly stock.
I think im having the same problem as talked about above. But Im not sure..
I had the truck towed to a shop (im not home right now) and they did a compression test and said my motor is toast.. anyway i dont believe that
heres whats going on.. Its blowing smoke really bad. Im not loosing any coolant, The smoke under hood is coming from the oil fill cap
99 ford f250 - YouTube
Old Jan 1, 2012 | 07:28 PM
Riffraff Diesel
PREMIUM SPONSOR
Welcome to FTE!
Can't be sure but with that kind of smoke and the pulsing of it in firing rythm out of the oil fill it is possible. Did they give you the compression test numbers? That is the true test because it is hard to tell on the video.
Old Jan 1, 2012 | 07:33 PM
Bonanza35's Avatar
Bonanza35
If they did a compression test what are the numbers. Will the cap on the oil fill tube stay on when placed upside down. I it stays on when placed upside down you are not building excess pressure in the crankcase. You mit have only blown the turbo seal. There lots of resent posts on here try and look them up. They had to pull the valve covers to do a compression test along with the glow plugs. Did they do that? Is it a diesel shop that knows our 7.3 PSD motors? I'm not much help we need to know more!
Chet
clangley's Avatar
clangley
All cylinders were between 250-375 #5 was 250
Old Jan 1, 2012 | 07:57 PM
Bonanza35's Avatar
Bonanza35
Number 5 is bad for sure! Cylinders should be closer to 400psi is what I've been told. Time to pull the heads. Bore scope it if possible, but with 250psi if done right its bad. Hopefully its a valve but that hasn't been the case in most cases.
Chet
Old Jan 1, 2012 | 08:03 PM
clangley's Avatar
clangley
the shop that did the compression test was houston performance diesel
1-325
3-350
5-275
7-325
2-350
4-325
6-375
8-350
Old Jan 1, 2012 | 09:24 PM
Bonanza35's Avatar
Bonanza35
1-325
3-350
5-275
7-325
2-350
4-325
6-375
8-350
Actually from what I've read, anything below 350 could start to be a problem. With thoses numbers and there gauge they all look close except #5. If your home and can do the work pull the head off and take a look. Or at least take a second test yourself, compression test. You can also pull the turbo if you think thats the problem and take a look. Wish I could help more then that, maybe someone else will check in soon. god bless,
Chet
Mudslinger72315
6.4L Power Stroke Diesel
Mar 19, 2014 06:49 PM
All leather
General Diesel Discussion
Feb 28, 2014 06:53 AM
gjnicholas
Oct 5, 2011 07:10 PM
4Wheelz
32
Jul 17, 2010 09:52 AM
94I-6
4 Cylinder Engines
Oct 20, 2003 11:27 AM
