New heads
Old Dec 9, 2011 | 11:35 AM
4inchlovin's Avatar
4inchlovin
New heads
So if I wanted to grab some new or "new to me" heads for my 65 that have hardened seats what should i look for? just 390 heads? or is there going to be an advantage or disadvantage to different style heads?
As always thanks for the help!
P.S '65 has a 352 with a 4 speed
Old Dec 9, 2011 | 12:12 PM
rustywheel68's Avatar
rustywheel68
there's definitely advantages to certain heads. particularly depending on the application.
you'd be better off asking this question in the FE engine forum- lots of smart guys over there.
hardened seats started showing up around '72, but you can have your local machine shop put hardened seats in the earlier heads.
Old Dec 9, 2011 | 07:10 PM
4inchlovin's Avatar
4inchlovin
ya i know thats an option but id rather just find a set with hardend seat and put them on my motor. Also slightly toying with the idea of just buying some new heads. The truck is going to just be a daily driver nothing special for a long time so im not to worried about putting something fancy on there just some that are going to make it run consistant and not clak lol
Old Dec 10, 2011 | 08:47 PM
1972RedNeck's Avatar
1972RedNeck
If your heads are original, they have bigger ports than all the heads I know of with factory hardened valve seats. I think the ones with factory hard seats were tempered or something of the sort. If you take yours to a machine shop, they will put in hardened inserts. In my opinion, these are far superior.
Old Dec 11, 2011 | 12:37 AM
4inchlovin's Avatar
4inchlovin
Thanks for the insight redneck... I talked to my buddy that works for the best machinist around and I think im convinved just to pull my heads and have them put in hardened seats and clean them up.
Old Dec 19, 2011 | 03:54 PM
4inchlovin's Avatar
4inchlovin
just found these any idea if per the casting # if they had hardened seats from the factory???
Ford FE Heads
Old Dec 19, 2011 | 04:03 PM
rustywheel68
C8=1968
i wouldn't expect to see hardened seats before D2 (1972). hopefully someone will have better info.
Old Dec 19, 2011 | 04:19 PM
Jetcopterpilot's Avatar
Jetcopterpilot
Stick with your stock heads, and just have the seats redone... aftermarket aluminum heads will change what cam and springs you will need. and better breathing heads while they will increase performance, will lower Vacuum pressure.. if you have an automatic trans, that will alter the shift points.... You could be opening up a can of worms.... if this is an everyday driver, just have the heads rebuilt with the new seats, a valve job and mill the heads while you are at it... A good machine shop should do the whole deal for about $3oo for both heads, and usually they will warranty their work for a year...
Old Dec 19, 2011 | 06:39 PM
1972RedNeck
If my memory serves me right, only D2TE-AA's had hardened seats. These were also small ported heads.
Old Dec 19, 2011 | 06:50 PM
4inchlovin's Avatar
4inchlovin
I know i should just stick with the stock heads i was just dreaming a bit i know bigger isnt ALWAYS better... hahaha
Old Aug 6, 2012 | 02:20 AM
4inchlovin's Avatar
4inchlovin
So the main reason i was intrested in getting new head is because it had a bad clack and i was figuring that was due to not having hardened seats and the valves being out of adjustment. Well today i finally had time to pull the valve covers and see what might be going on. I found this. A nicely bet push rod. So i checked everything out and the lifted is still in place and the valve is not collapsed so im going to throw a new $3 push rod in it and see what happens.
fordman400
Aug 19, 2010 08:29 AM
Slicksixtysix
19
Dec 29, 2008 11:05 AM
JDenver
Dec 3, 2007 05:39 PM
7FORD2
Apr 19, 2006 11:58 AM
chromiumh1
Nov 16, 2004 08:08 AM
