another heater question
Old Dec 9, 2011 | 08:42 AM
bamaf150's Avatar
bamaf150
While I wait for a vacuum switch to to arrive to go behind the dash (defrost blows constant, no detents felt in climate switch) is there something I can do under there manually to direct radiator water into the heater core and get some heat; disconnect a vacuum hose etc? thanks
Old Dec 9, 2011 | 10:03 AM
bamaf150's Avatar
bamaf150
Wondering if I remove the vac motor in the hose between the heater core and the pump and put a hose barb there, should I get heat?
Old Dec 9, 2011 | 10:29 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Remember that they advise to use vacuum to open/close these doors to avoid damaging the controllers. Sorry for the large pics. So you can read the small print....
If you can't pm me a good addy and I will send them to you email
Old Dec 9, 2011 | 11:15 AM
OldStyle's Avatar
OldStyle
Rusty Roller
I'll put this here too. Hope all works out!
Link below:
MediaFire Files
Old Dec 9, 2011 | 11:21 AM
bamaf150's Avatar
bamaf150
Thanks Oldstyle.
Old Dec 9, 2011 | 01:40 PM
bamaf150's Avatar
bamaf150
Well, to get heat, I manually operated the vacuum valve in the heater hose so at least I wont freeze to death while I wait for the vacuum switch. Defrost blows warm to hot now, temp control works.
Old Dec 9, 2011 | 06:51 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Hot is much better that cold!
BillM2
Oct 15, 2015 03:19 PM
WyoFlyFisher
Dec 15, 2011 04:22 PM
nixvet2000
1978 - 1996 Big Bronco
Feb 24, 2009 08:29 PM
Hottarod
Nov 3, 2001 12:30 PM
chille72
Dec 22, 2000 07:52 PM
