serial no. location
Old Dec 9, 2011 | 05:57 AM
jbell110's Avatar
jbell110
serial no. location
Hi there, I'm trying to get some parts from LMC but I need a serial No.
I have a 12/76 f250 4x4, where do I find the serial No. ?
Nothing on the vin plate or under the bonnet that I can find,
any help would be great !!!
thanks Jeff
Old Dec 9, 2011 | 07:27 AM
earthquake68's Avatar
earthquake68
The vin IS the serial number.
Old Dec 9, 2011 | 08:31 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The serial number is the LAST six digits of the VIN.
From '73-'77 it's one letter and five numbers, '78-'79 it's two letters and four numbers.
Eg: VIN F10YNR65733 the serial number is R65733.
Old Dec 9, 2011 | 09:30 AM
littlecobra1977's Avatar
littlecobra1977
Not to hijack the thread, but some one has changed the cab on my F250. I have the title for the cab, but I am not sure what the frames year is. Is there any way to tell what year the frame is? I was under the impression that there is also some sort of markings on the frame, if so where are they located? Thank you.
Also heres a weird one, The title says 1979, but looking up the first 3 letters-numbers it says its a 73? Ok can I get a run down on this VIN? F26HCDJ7284.
Old Dec 9, 2011 | 10:10 AM
400 .040over's Avatar
400 .040over
littlecobra1977 look on the pass.side of the frame near teh alt.,mite have to clean the frame to see it tho
Old Dec 9, 2011 | 11:41 AM
mikeo0o0o0's Avatar
mikeo0o0o0
F26HCDJ7284
F26=F250 4WD pick up
H=351 2bbl V8 engine
C=Ontario Truck plant
DJ7284=1979 model year consecutive serial number
Like 400 .040 over said the VIN number is also stamped on the top side of the right (passenger) side frame rail. It can be anywhere between the firewall and radiator support but is commonly found about inline with the alternator.
There is a second, hidden VIN. It's also on the top right frame rail under the cab about 8"-12" behind the front cab mount.
Just so you know, most states require the frame VIN be the one used for title purposes.
Old Dec 9, 2011 | 12:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by littlecobra77
Is there anyway to tell what year the frame is?
The frame ID number is stamped on the right (passenger) side outer frame rail, usually between the right front wheel and the bumper.
NOTE: Some VIN's will be found stamped on the top of the left (drivers) side frame rail adjacent to the steering gear box.
ALL vehicles have a hidden VIN, the trick is to find it. Today, many are hidden by rust and road grime.
Old Dec 9, 2011 | 12:11 PM
earthquake68
Don't get upset if you don't find a vin on the frame. Apparently, my truck was never stamped.
Old Dec 9, 2011 | 01:34 PM
littlecobra1977
Thank you all for the advice, I will look and see what I find out. Of coarse the truck has the front end so that will make it fun but we'll see.
(Just so you know, most states require the frame VIN be the one used for title purposes.)
Im sure there is but the PO had it licened before me, I have the original tag for the previous cab that was on the frame as well. But was giving the current title to the current cab. I hope that makes some sence. I am not sure or up on the laws as too cab swaps, I live in Illinois, they dont concern theirselves with that unless there is a suspition to some wrong doing.
Old Dec 9, 2011 | 06:44 PM
jbell110's Avatar
jbell110
Thanks for the replies & I'll post my vin for decoding
F26SNX93740
thanks Jeff
Old Dec 9, 2011 | 06:53 PM
mikeo0o0o0's Avatar
mikeo0o0o0
F26SNX93740
F26=F250 4WD pickup
S=400 cu in 2bbl V8
N=Norfolk assy plant
X93740=1977 model year consecutive s/n (1977 goes from X80,001-Z25,000)
Old Dec 9, 2011 | 07:57 PM
jbell110's Avatar
jbell110
Looks like mines a 77 highboy not 76, have to change my profile!!
thanks Jeff
Old Dec 9, 2011 | 08:25 PM
Ramlock's Avatar
Ramlock
^^This^^
Psmith1951
May 9, 2014 11:13 AM
taylor17
Large Truck
Oct 31, 2010 01:55 AM
mercurycat
1947 and Older Ford Trucks
Feb 28, 2010 10:59 PM
Markcuda
13
Nov 5, 2006 01:42 PM
bgbass
Jun 24, 2004 07:38 PM
