262 Block Heater
Old Dec 8, 2011 | 07:56 PM
1972RedNeck's Avatar
1972RedNeck
262 Block Heater
Did Ford ever install a factory (or dealer) block heater for a 262 in a 1964 F100? If so, what is the part number? Napa doesn't even list the 262 OR 223 in their book (I assume they would be the same?) Was the 262 ever used in another application?
Old Dec 8, 2011 | 11:14 PM
garbz2's Avatar
garbz2
you need to measure the diameter of the freeze plug that it would go in a purchase the appropriate unit. A better unit for this case would be a oil pan heater blanket.
The 223 and 262 do not share the same block.
262 was available in F series trucks as a option from 61 to 64.
Garbz
Old Dec 9, 2011 | 01:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5AZ-6026-G .. Core Plug-Cup Type-Clean out holes in block and head / 2.078" O.D.
Applications: 1964 223/262 I-6 / 1965 240/300 I-6 ~ NOTE (1) used at rear of block only, no where else / 1968/74 240 I-6 & 1968/79 300 I-6.
The block heater was available at the parts counter or as a dealer installed accessory.
The only block heater kit part numbers I can find, are for FE engines, or 1976 and later 300 I-6's. Both are 600 watts.
Old Dec 11, 2011 | 11:56 AM
tripleframe's Avatar
tripleframe
1972 was the first year for this factory option on pickups.
Old Dec 11, 2011 | 02:28 PM
1972RedNeck
I just picked up an oil pan patch. It should do the trick.
Big Black Dually
22
Dec 9, 2016 12:32 PM
2gumby2
2015 - 2020 F150
Apr 6, 2016 11:30 AM
mmusky1
Oct 26, 2007 08:15 PM
chains
2004 - 2008 F150
Nov 9, 2005 11:21 AM
DT 466Man
Sep 27, 2004 09:17 PM
