CEL Codes
Old Dec 7, 2011 | 08:50 PM
kalpesh's Avatar
kalpesh
CEL Codes
just purchased my own OBD2 scan tool....innova3130, over 60% off of list price couldn't resist
here are my codes
P0305 - CYLINDER 5 MISFIRE
P0174 - SYSTEM TO LEAN (BANK 2)
P0306 - CYLINDER 6 MISFIRE
P1288 - CYLINDER HEAD TEMP OUT OF SELF TEST RANGE
P1464 - A/C DEMAND OUT OF SELF TEST RANGE.
i have replaced all the plugs bought from the dealer, now i am thinking the misfires are due to the coil packs
any other ideas ... please list them...
Old Dec 7, 2011 | 09:21 PM
D-Cell_Mekanick's Avatar
D-Cell_Mekanick
I picked up the 3160 earlier this year off of Amazon.com for a sweet price. I've got a websight that will give you a good deal of knowledge on obdII codes: http://www.obd-codes.com/trouble_codes/. Hope that helps.
Old Dec 8, 2011 | 06:26 AM
projectSHO89's Avatar
projectSHO89
For technical assistance, you need to provide the year, model, engine, and other specifics for your vehicle. We are not psychic.
Also, please do not start a new thread for for each question you have on an on-going issue or project... Keep everything in one place.
Old Dec 8, 2011 | 08:12 AM
kalpesh's Avatar
kalpesh
my appoligies, 2000 expedition eddie bauer 5.4L
i would think that CEL codes would not get a response under should i go with a magnaflow cat or a oem cat.
Old Dec 8, 2011 | 08:27 AM
alwaysfords41's Avatar
alwaysfords41
It is very hard to follow you....you're in 10 threads on various topics and now you are mixing your questions and responses among them.
Old Dec 8, 2011 | 05:04 PM
pdqford's Avatar
pdqford
here are my codes
Starting at the bottom:
When you scan the engine, you should have the HVAC system turned off.
And the engine should be at normal operating temperature.
You probably have a small vacuum leak on bank 2, which may be causing the misfires on that bank.
Can your scan tool pull up the 'freeze frame' data?
Old Dec 8, 2011 | 05:06 PM
kalpesh's Avatar
kalpesh
I think it can just trying to learn how to use it
zmt
27
Oct 23, 2017 06:51 AM
MStakes
Jul 5, 2014 11:59 AM
rbsample
Jul 25, 2011 09:26 AM
88f150302
1997 - 2003 F150
Dec 14, 2010 11:43 AM
the deno
Jan 15, 2007 10:30 AM
